Posted: Sat Oct 11, 2008 11:29 pm Post subject: Re: Anybody got an E21 on the zone?
Hi
I have got a few e21's
For the m30 swap you need custom mounts about £100 an early 5/6 series box with a mech speedo output or use the orginal box till it breaks (if it does)
Electric fuel pump
The manifold will need to be custom, or at least the down pipes
You need to shorten the prop shaft as it is a tight fit
Rear diffs can be week so new oil and no 3k launches.
LSD are rare and very expensive, plus you can do an e12 rear diff conversion
You also want some braek upgrades volvo 240 4 pots and 323i rear trailign arms
Plus join bmwe21.net
Jason
Thanks Jason for the input, much appreciated.
Have you done the M30 conversion and how much was the total bill?
Lsd not interested as i think there too much money, open diff is fine for my style of driving as i'm only going to use this as a SLEEPER
The car is a 316 with webber conversion, but on a auto box, no electrics, and interior is in very good nick.
Where would i get the mounts from, prop not a problem, and when you say 323i rear trailing arms, do you mean from a nother e21 or e30????
Can i not do a e30 mod for the brakes as i have access to a lot of e30 mechanicals.
And you got any pics of your cars?
