bmw e30 m3 evo engine?
GrindCulture
Possible? Yes. Cheap? No. Easy? No. Awesome? Yes
Not in E30s any more
e30bmlover
- Ac Schnitzer prophet
will you be doing any of the work yourself?
A tech should be able to sort you out not sure where exactly ant is located but im sure its down that waye30dal wrote:e30bmlover wrote:will you be doing any of the work yourself?
no mate all work would be done properly i'm from dartford i know there is a comany in west kingsdown so i'll go to them
e30bmlover
mate its going to cost you allot more than 3k to stick a s50b32 in there! i would go the m20b28/b25 route,e30dal wrote:e30bmlover wrote:will you be doing any of the work yourself?
the more i think about it, the more i like the idea of an s50 in my m3.
whilst i'd hate to lose the s14, id love the reliable power and torque of even just an s50b30 280ish bhp in an e30 has got to make a quick car. plus parts avaliability would be a big advantage.
i'd still keep the s14 tucked away to be able to return the car to stock at somepoint, or even just to turn into a statue in the livingroom
you can pick up an s50b30 in good condittion, with ecu, loom, sensors, keys for around a grang, a gearbox for £200, what else is there on top of that?
clutch, engine and gearbox mounts, exhaust manifold would be the hardest bit, but handily an m3 doesnt have steering linkage complications. brake servo. m3 has a decent radiator, and electric fan, m3 prop and diff are ideal anyway...
cheers,
harry
harry
The first time you put your foot down in an S50'd E30, you'll soon forget about the handling balance! Its not that bad anyway.
