Zayyan wrote:Are the normal (now red) indicators too red even with amber bulbs?
If so how did you do the reverse light/indicator swap?
I didn't notice that much, until it was git dark.
amber bulbs in the indicators doesn't work too well.
to get the reverse lights as indicators, replace the bulbs with amber ones
then remove the plug and unclip the back.
The wires which go to these pins are for the indicator and reverse lights.(reversed on the other side)
unclip the long blue/black wire (you will see which one when the plug is open) and plug it into the other hole. leave the shorter wire disconnected.
If this description is crap, Im sorry. I NEED sleep. I will try to go into more detail later. Im like the walking dead at the mo!
