latch on body which door is closed on
check the hinges / a pillar, if the front had dropped no amount of adjustment at the back will get it sitting right.
i've found a small plastic ruler is the perfect tool for setting them up, just adjust, nit pu tight, close door and use the straight edge to make sure it's flush. if not, open up, move latch a mm or two whichever way and try again.
not sure photos will be much help, theyre designed to be adjustable as every car will have slightly different tollerances, and so every door is checked and alined by a human being on the production line.
cheers,
harry
harry
