Hi, I've just purchased a H plate motorsport convertible but it unfortunately has an issue with the electric roof not functioning correctly. I've taken it to TCS in High Wycombe who re synced it after fitting a new motor. It worked for 2 days and has now stopped working again. They are not sure what is causing the problem. Does anybody know a hood specialist that doesn't charge the earth? I live in Watford so anywhere close by would be good?
Many Thanks
Maddogg
Hood Beef
Try C E Moores Coachtrimmers. They do all the work for BMW Heathrow and are excellent. I had my hood changed and fitted as well as had my rear leather seat re-stitched and the leather re-connolised. They did an excellent job.
Speak to Steve. Tell them that Lizzie, from the E30Zone recommended you.
http://www.cemoore.co.uk/index.htm
Cabgirl AKA Lizzie
1990 325i Auto with Switchable Sports Mode Convertible with just 100003 miles on the clock.
Rosc0PColtrane
Convert it to manual. Zero hassle and a roof that retracts in under 10 seconds.
I must admit, I am so pleased I went for the manual hood and not the power hood. For one reason, they go wrong all the time, but secondly, I have so much boot space compared to the power hood versions. I can get a large suitcase in mine without any problems. It isn't that way with the power hood.
I hope that you get your hood sorted soon, it must be a real hassle. It takes me seconds to get my hood down and stored away. I may have to get out of my car to pull a lever and close the hood mechanisms, but it has never caused me a problem. I hope that C E Moores will be able to help you.
Cabgirl AKA Lizzie
Thank you for your input. From what you said Cabgirl i decided to try my local coachtrimmers Hukes of Hemel Hempstead who have rectified all the problems for £100.00 + v.a.t. Result...
Thanks for your advice
Mad dogg
Mad dogg
I'm pleased that my advice worked out one way or another and that you got all the problems rectified so quickly.
Cabgirl AKA Lizzie
