What spark plugs do you use?
SilverShadow
- Hartge Crew
Hi Guys
i wanted a general idea in what spark plugs you use on your e30.
Im hoping to have the H27 started up this weekend but i need to change the sparks plugs that are currently in it (bosch w8lcr).
What do you reconmend and why?
At the end of the thread did Brian mean BPR6ES - just want to confirm as I need to change the ones in my 2.5 ?
Previously owned loads of old E30s, E34s, a few E36s, E32s, E39s and an E38.
Currently in a diesel Audi - miss me old E30's....
greentouring
NGKs have worked well on my touring. I got 4 brand new from ebay for under a tenner ;) These so called 'more power' plugs are a total waste of money as far as I can see, so don't be tempted.
shedrool83
SilverShadow
- Hartge Crew
Wheres the best place to pick up the NGK plugs?
Halfruads?
Halfruads?
Just had a look on EBay - 6 plugs + postage £10.70 all in - think that's pretty good
http://cgi.ebay.co.uk/NGK-SPARK-PLUGS-B ... 286.c0.m14
That seem a very good price to me... They're £2 each from my local stores!
Breaking 325i Touring
SilverShadow
- Hartge Crew
I picked up the NGK BPR6ES from a local store and they don't fit into the HT lead???
Which NGK's are they supposed to be
NGK BBR6ES?
NGK BBR6ES?
SilverShadow
- Hartge Crew
I tried doing this with one of the plugs yesterday and the plug just fell apart?fingerman wrote:I found this on the BPR6ES - pull off the little metal cover and they fit
Did you puill the right end - mine just twisted off with ease
BPR6ES are the recommended ones (old m20) so this sounds a bit strange
SilverShadow
- Hartge Crew
Well i tried to unscrew it and the whole rod thing came out of the plug?
Are you sure they are not supposed to be:
NGK BBR6ES?
NGK BBR6ES?
SilverShadow
- Hartge Crew
Just got off the phone to GSF they have given me NGK ZGR5A??
They said that they don't recall BBR6ES and BPR6ES??
hmmm, some more dodgy ngk's...
I had a really bad time fault finding a misfire on my car which after checking everything turned out to be the plugs.
see thread..
http://www.e30zone.net/modules.php?name ... sc&start=0
These ngk's were less than a month old and they progressively got worse very quickly. I went with the standard bosch single prong plug and haven't had any problems since.
see thread..
SilverShadow
- Hartge Crew
The guys at the local store gave me the wrong plugs they were BPR6ES-11
They replaced them with the correct BPR6ES
Got 2 packs of 4 for £9
Whats the best gap to set these plugs up? 0.25mm?
