thanks............
5 stud conversion (CONFUSED)
i have a e34 5 series 535i...... i am using this as a donor car i wanted to change my 4 stud to 5 stud can i use my 5 series whole suspension.... or are they not any good please as much info would be nice as i do not no much about stud conversions and what about the rear?
thanks............
thanks............
Hi guys on your 4to 5stud subject try MARLIN SPORTSCARS i know you can use B M W AS DONOR cars and i have seen an article on running gear they used 4 to 5 stud type spacers it gave them a wider choice of wheels http://www.marlinsportscars.co.uk/spors ... nformation cheers hb
From memory, the spacers put the offset into + numbers. ie, way too much sticking out. I think they used 2 sets, 4x100-5x114, then 5x114-5x120HB wrote:Hi guys on your 4to 5stud subject try MARLIN SPORTSCARS i know you can use B M W AS DONOR cars and i have seen an article on running gear they used 4 to 5 stud type spacers it gave them a wider choice of wheels http://www.marlinsportscars.co.uk/spors ... nformation cheers hb
jaistanley
Clarify what's nasty. With geometry specs.dips346 wrote:nasty mix of e36 coupe and compact stuff
Popular misconception. They don't fit. The bottom of E28 struts are different to E30 M3 so the plates dont fit.oze30 wrote:E28 legs will fit, but you need the E30 M3 bottom plate for it to work.
The easiest way is to fit 5 stud is, of course, use E30 M3 stuff. You can get perfectly acceptable geometry using a mixture of E36 parts. A few people that don't do their homework have fitted the wrong E36 stuff, or read about it on american forums, and have got less than std E30 allignment. Using E30 M3 offset TCA bushes, M3 Evo TCA's, E36 M3 hubs and struts and E30 springs you can get alignment the same as E30 M3 but with 20 minutes less camber. Fixable with either BMW offset or adjustable topmounts.
