how safe do you rate these as a concept:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=025
DIY Coilovers
- Brian28
- Contact:
The threaded tube is welded onto the original strut, we've used them for racing with no problems. In the UK DT amongst others do them, I think ours came from rally spares, something like rallyspares.co.uk Fronts only though, as the E30 doesn't have a rear strut to convert to coilover. There are some good photos (not mine) of a conversion before during and after on the motorsport forum.
dips346
- London Meets Main Man
these arnt the welded type ,these just sit in placeBrian28 wrote:The threaded tube is welded onto the original strut, we've used them for racing with no problems. In the UK DT amongst others do them, I think ours came from rally spares, something like rallyspares.co.uk Fronts only though, as the E30 doesn't have a rear strut to convert to coilover. There are some good photos (not mine) of a conversion before during and after on the motorsport forum.
Been used on e30´s loads of times.
most of them just have generic springs rates. 450lbs or 350lbs depending on totall randomness.
- Brian28
- Contact:
My bad. In that case I wouldn't be a fan. Not unsafe I'm sure, but not sure how tight they'd fit on the strut to stay in position when unloaded, eg jacking the car up or the inside wheels on a long corner. I'd buy a weld on kit conversion kit seperately and springs seperately so you can get something to suit you rather than a generic spring kit with lb/in based on who knows what.dips346 wrote:
- Brian28
- Contact:
Depends what parts I guess but generally, nope. I've welded coilover conversions like above and modified front top mounts by cutting and welding, never had any problems.
cliffybabe
- Powered by Nelly
depends how wel the jobs been doneOnz wrote:but isnt welding suspension parts an MOT faliure?
- Brian28
- Contact:
Nope, any decent standard welding is fine even if obviously done to parts afterwards. The only suspension thing I can think of that would be a fail is if somebody tries something dopey like welding a snapped coil spring to repair it, I may have bodged some solutions in my time but even I haven't tried that oneOnz wrote:you mean how factory it looks ;)
Le Mans Classic 2006
