lsd for motorsport
if you don't know the benefits, why do you want one?
basically instead of one wheel spinning and losing traction, the LSD distributes torque to both wheels - therefore providing more grip and drive
An LSD with the same ratio as you have now will reduce fuel economy I'd imagine as there is more mechanicals to turn albeit very little but certainly wouldn't make fuel economy better.
The way you would increase fuel economy is if you were doing alot of motorway miles and changing to a lower ratio diff. This would make the engine run alittle bit slower when cruising.
Dave_M3 wrote:An LSD with the same ratio as you have now will reduce fuel economy I'd imagine as there is more mechanicals to turn albeit very little but certainly wouldn't make fuel economy better.
Ive got a 3.73 (rare) LSD for sale, ideal for motorsports
if you want to give it a bit of welly then go for the 3.91 ....if you are a bit more grown up and think economy is more important go for the 3.64.......as for a lsd do you really need it are you worried when you want to get both back wheels to spin at the same time ...if so you are in the welly catagory and go for a 3.91 and thrash the bollocks of it
as you have a motorsport cab i tend to think of you as more grown up so go for the 3.64 and forget about wheels spinning
e30bmlover
- Ac Schnitzer prophet
too right bob..... winners have the 3.64 slipper!!Bob_S wrote:3.64 all the way it's a hero's diff 3.91's are for 4 pots
