9j all round?
nav786
in two minds. shall i go for 9j all round for deep dish look all round, or 7.5j upfront and 9j rear, with dish on rears only.
if i do go for 9j all round, will they work on the front with ET15
FOR SALE
SONY PSP'S £100
psychochild187
for track i would use all the same size
but for looks the rears bigger!
i voted rears bigger as u have tv screens so looks are more !
hmmmm deep dish
hmmmm deep dish
Jesus325iTouring
- Frog freak !
I would love to vote and help you decide Nav,only trouble is I haven't a fcuking clue what your talking about!
Whats the j all about?
Sorry,being dim tonight!
psychochild187
it the size of the wight of the wheel
like 205 or 225 or what ever ive no idea wat the 9 or 7.5 is the same as thou
Jesus325iTouring
- Frog freak !
Ah,now I understand 205,225 and all that.psychochild187 wrote:it the size of the wight of the wheel
Naz,whats the equivilent to what you have written in those terms?
eko
- Old timer
Jesus,I think the J stands for inches
example 9inch wide rears and 7 half inch wide fronts
Quaser
HI Nav
I think that alpina had smaller at the front, and larger at the rear, and that it helped with the stability of the car.
f you go too wide at the front, your car will tramline a lot due to there being so much contact with the road. You will feel every bump through the steering wheel, and the car may often follow the contours of the road which lorrys have left due to wear and tear!
Dont go too wide at the front in my opinion!
Q
Q
panesar_e30
wassup nav?
go for 7.5's on the front and a 9 on the back. 9's look odd on the front and gibe the car a trackter ki
nd of look.
Jesus325iTouring
- Frog freak !
Sortedeko wrote:Jesus,I think the J stands for inchesexample 9inch wide rears and 7 half inch wide fronts
Cheers from above
nav786
cheers guys, yep jesus, the j just stands for the width in inches. i have no idea why j though
i was worried about tramlining, so i will probably go for 7.5. i just like the deep dish look though.
FOR SALE
SONY PSP'S £100
Ziggy
IIRC, the "J" is the type of lip on the rim - virtually all rims are J though these days.
320Touring
the J actually stands for "Jesus, these rims are wide"Jesus325iTouring wrote:Sortedeko wrote:Jesus,I think the J stands for inchesexample 9inch wide rears and 7 half inch wide fronts
Cheers from above
Moofles
i believe tramlining is much more affected by profile than width of tyre/wheel...tramlining is caused by the inability of the tyre to deform to the shape of the road and absorb the imperfection...hence the wheel instead turns itself to fit in to its most natural position...a wide tyre would have no difference to a thin tyre, unless you are saying the tramlines will be wide enough that a thin tyre will have plenty of room for manoeuvre and the wide tyre will touch the edges easily. and that's quite dependent on an individual tramline, so probably not possible to say such generalised statements like 'wide tyres tramline more' (unless you have a reason i don't know about, and i don't claim to be an expert
'08 GSX-R750, '02 CBR600F, and a beast of a Focus 1.8LX...
My old sig
- http://img52.imageshack.us/img52/2652/funnyface8eg.gif
My old sig
Kam320i_cab
its true about wat quaser says, like the alpina came with narrower fronts and wider rears, its for handling/performance/stability, most race cars have this setup like the F1 cars
I also think if u get dished wheels if the front are narower and the rears are wide then it looks realy good too
gives an effect of em being wider
glenn
- Engine Transplant Services
nav,
i have 8.5 all round on mine with et15 offset,the backs are inside the arch's but the front's stick out too much ( they were bought for a different car)
the 'j' is for where the 'well' is on the wheel
