alpina locks
jordano
Post Sat Jun 04, 2005 10:28 am
does anyone know if you can get the alpina wheel cap locks from appart from dealers?
TOURINGDADDY
Post Sat Jun 04, 2005 10:32 am
Barrels u should b able to get from any good lock smith shop :D
Richy325iTouring
Post Sat Jun 04, 2005 10:58 am
dealer only cosof the shape on the dead bolt bit
allthough im working on a dead of dead bolts with a longer flap bit that needs cutting down and shaping to suit the alpina locks
they work out at 25 for for instead of 120 lol
jordano
Post Sat Jun 04, 2005 1:23 pm
Thanks Richie im up for a set when can you tell me where to get them Ԛ£25 souds great took my wheels off for a clean and lost the keys lol
Richy325iTouring
Post Sat Jun 04, 2005 1:48 pm
local parts place has the locks they look well simular just the dead bolt it is hugggggggggeeeeeeeeeeeeeeeeeeeee
some cleaver trimming though and and bending and i think they should do the job
Lowm3
Post Sat Jun 04, 2005 6:13 pm
i was about to ask the same question, so can a lock smith sort out a key if you remove the barrel from the centre cap?
JonnyDrift
Post Mon Jun 06, 2005 12:08 pm
It seems someone else has the same problem.I have a broken key for the lock but the serial number is still on it.But you cant buy the keys on their own,they have to be with the locks.So im looking at Ԛ£120 for 4 from my local BMW garage.Rear tyres are done too-i need to get it sorted soon.Is there a cheaper way?
Lowm3
Post Mon Jun 06, 2005 12:24 pm
I'm sure you should be able to buy 4 barrels of the same spec, just not bmw, with keys for alot less than Ԛ£120 quid.
Right just had a word with a mate that used to be in the trade, he said you can get a locksmith to cut a key for the barrel if you have lost the key, but not sure if they can do it ..
as for the barrels, they used to take them out and get a new set and put them in. He said they didn't fit as well as the original barrels but they work fine.
