- Contact:
Rolled the cabby out my way, did some bits on other cars, then rolled it back in the way!!!
Did also finally get a stereo wired up in my touring so it now makes even more noise, and replaced the check panel I couldn't get out previously - and replaced the manky old coolant level sensor - though the light still stays on!!!
327 Touring with bass!!!
- Tech 1 freak
Took it out of hibernation and gave it a good wash. Only drove it up and down to the hose in the car park, enough to realise how nice it is to be behind the wheel of an E30 once more. The E21 has character but is woeful when compared to an E30.
1982 E21 316 Baltic Blau
1989 318i 2 Door Sterling Silber
Feedback: http://www.e30zone.net/modules.php?name ... highlight=
Took a few dents out and fitted an OE leather hand brake handle and gator
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
- **BANNED**
Just passed my MOT after a initial failure on brake imbalance, chatting to the guy he said the new system has changed it so they can't feather the brake or something they have to just brake and the machine does the rest, anyway I stripped the calipers off cleaned them and emery cloth the pads alittle then did a few 70mph-0 stops and took it back in and he passed it streight away. The calipers were clean as a whistle inside so I think it was the stops that did more of the fixing.G-Bear wrote:New engine mounts in.. Failed MOT, start research on brake imbalance..
- Zone day release
- Location: Somewhere in Hertfordshire , or press Ctrl + W
feeeeeecking rusty brake pipes. Now replacing more than just the rear. rear axel on the floor along with the tank, fuel pipes ect... feeeeeeeeeeeeeeeeck but it will be done by the weekend I hope, may be the weekend after
. could ruine my pod day out as I have a week away to pay for.
I'll be back in a straight jacket before the end of the year.
- Tech 1 freak
Bought an m30b35 with dog leg box to pop in
pushed my luck too far and ended up without a clutch in the York rush hour.
I don't know exactly how much the Police recovery is going to cost, but it won't be cheap
last time poice recoverd my car it cost me £350Morat wrote:pushed my luck too far and ended up without a clutch in the York rush hour.
Last night on my own I fitted a replacement diff on the driveway in a couple of hours. It took longer in a garage with help before so I'm impressed that it went smoothly and didn't take long.
Just hope this one lasts now, all bolts done up properly this time though and with the use of medium thread lock.
1988 325i Cabriolet - Gone.
On Monday I taxed it, washed it and did a temporary bodge fix on the wiring to the speedo sensor in the diff
and yesterday I drove it to work and back - it stood out like a sore thumb in the office carpark full of modern stuff
MOT'd it, at Kwik-fit of all places and passed!
Only advisory was a little chip in the windscreen.
Put £40 worth of petrol in and its nearly all gone.
- Tech 1 freak
Lee you are clearly not doing enough miles each year in that beast
What were your emissions like?
I will this year, MOT was the least of my worries Jim, check my thread.
Ill have a look at the emissions tomorrow, i didnt care at the time as i just wanted back on the road.
What wheels are you running??
MY FACEBOOK PAGE- CLASSIC STANCE
http://www.facebook.com/pages/Classic-S ... 6444884427
MY FOUR EYED BEAST
MY FOUR EYED BEAST
- Location: In your back passage faster than a rat up a drainpipe!
Got my ELECTRIC roof working!!!!!
Just need to do minor things on it now, like lube all the moving parts, alter the rod lenghts, so the movement is precise and finally put the sleeve over the small bar that raises the horseshoe to stop the roof material being soiled when it's stored in the compartment.
Roof itself needs to be sorted so that it folds properly - usual fiddling with the tension straps.
Electric roofs aren't that big a deal!
Probably break again, now I've said that!
