Hottuning 6 branch
Post Thu Feb 21, 2008 6:00 pm
daimlerman wrote:
sansarpur4eva wrote:
ShepsEvo3 wrote: I think you'll find that this was the test :wink:
my bad :o: I thought Louise was doing one seperate.
Far better that we have a result from a zoner than the supplier.I hope to fit mine tomorrow,I have made up my mind on the exhaust system issue and I am going with a standard centre and rear supplied by GSF.The money 'saved' over a Longlife S/S system will help pay for a mapping session after a cylinder head swap...
you going with a proper cylinder head this time?!
Onz
Post Thu Feb 21, 2008 6:02 pm
so... bottom line, is this as good as the btb2 or should Sal get some new stock?
oakey
Post Thu Feb 21, 2008 7:06 pm
Onz wrote:so... bottom line, is this as good as the btb2 or should Sal get some new stock?
I know which one I'd buy
Post Thu Feb 21, 2008 7:14 pm
We'll see what a btb does on my stock 325i in a couple of weeks.
Post Thu Feb 21, 2008 7:15 pm
bss325i wrote:We'll see what a btb does on my stock 325i in a couple of weeks.
M5pilot
Post Thu Feb 21, 2008 11:14 pm
Not investing in any more manifolds.
As for all of this '18bhp is a load of BS', myself and Ant were having a little talk about tuning M20's and we both agreed on one thing - ever since the BTB2 manifold has been around haven't we seen alot more 2.7's break the 220 bhp barrier? Funny that.
Oguz327 - 225+ bhp
Quaser's 2.7 - made well over 220bhp
Mine and my friends silver C2 - 220bhp +
Before this the most we ever saw out of 2.7's with Schrick cam, MAF conversion (basically similar spec as above but different manifold) was 210bhp. That engine had a funky super duper Griffen worked head aswell!
Nadeem Hejazi's old 325i sport had the same manifold, Schrick cam and a MAF conversion and that hit 195 bhp. This one was a joint project between A-Tech and Bexleys with myself supplying the parts.
Two other independant dyno sessions were done on the BTB and the results were not far off of 15 bhp
The results are out there, if you choose not to believe them that's fine but saying they are not possible.....well......I'm afraid they are guys.
I have nothing to gain from BTB2 sales anymore. The above is what I have seen over the last 2-3 years.
I was expecting to see alot more than that from the Hot tuning BTB copy, maybe the test needs to be done again but this time on a standard car without a chip. Maybe they need to look into the way the collectors are put together. I know from past experience what happens when the collectors are screwed up internally!
agent006
Post Fri Feb 22, 2008 8:20 am
[quote="M5pilot"] maybe the test needs to be done again but this time on a standard car without a chip[/quote]
But that goes against what you've said above though, that you've seen the biggest gains from cars that are already heavily modified.
Paynts
Post Fri Feb 22, 2008 9:29 am
Hm after reading all this thread looks like I need to pull my engine apart and go to a 2.7 lump with all the right internal parts + decent cam. What after market ECU do you reckon guys. My Alpha Weber is very time consuming to map It took all day to map it the other day the ECU has to come out, a development ECU has to go in with the orginal chip in then remapping can begin, then ecu pulled out, then a new chip blown and my orginal ecu fitted with the new chip
Maybe I should spend cash on a DTA one?
ShepsEvo3
Master of go faster
Post Fri Feb 22, 2008 11:08 am
agent006 wrote:
M5pilot wrote: maybe the test needs to be done again but this time on a standard car without a chip
The chip Simon has would be for a standard engine which isn't taking mods like this into account, but this test shows what is gained or lost when fitting this manifold as a "bolt on" with no other adjustments.
With ALL modifications, you will not benifit from them to thier full potential untill you remap the ECU to suit. This test was never about that but to see the gains/losses from just bolting on.
www.sabre-tuning.co.uk
march109
Post Fri Feb 22, 2008 11:30 am
Not really a fair test though, since the chip is generic I expect it was manufactured with the log manifold in mind and does not suit the new 6 branch. When Sal said the biggest gains are from heavily modded engines he is correct of course as long as the mods are complementary.
HairyScreech
Post Fri Feb 22, 2008 1:08 pm
just had a thought, is the extra enritchment in the 3000 range to help with the flat spot? and im assuming the flatspot is gone with the difference in the pulse tune of the exhaust therefore causing over fueling?
this is all a guess tho as im not tuning expert, yet.
ShepsEvo3
Master of go faster
Post Fri Feb 22, 2008 1:16 pm
HairyScreech wrote:just had a thought, is the extra enritchment in the 3000 range to help with the flat spot? and im assuming the flatspot is gone with the difference in the pulse tune of the exhaust therefore causing over fueling?
Yes! correct :wink: But there was no enrichment at that point with the standard manifold.
Maybe Simon can post up the AFR sheets?
snoops
Major Helmet
Post Fri Feb 22, 2008 2:14 pm
so the hot tuning manifold has been tested as standard but how about the hot tuning manifold with the welds sorted out as described in the very first thread in the ebay section?
oakey
Post Fri Feb 22, 2008 2:37 pm
snoops wrote:so the hot tuning manifold has been tested as standard but how about the hot tuning manifold with the welds sorted out as described in the very first thread in the ebay section?
This could go on forever :D . If the shape and design etc of the manifold has been copied from the btb (which I am led to believe it is) It doesnt make sense that it wont make the same power increase? Apart from the poor welds inside that is :D
agent006
Post Fri Feb 22, 2008 4:14 pm
I have one on my desk here, delivered yesterday. Most welds are fine but one of the header (1,2, and 3) sections is appallingly badly welded. Other sections seem fine and it all looks to be decent quality.
Post Fri Feb 22, 2008 4:18 pm
You lot wanna stop playing around with M20 scrap :D
**BANNED**
Post Fri Feb 22, 2008 5:56 pm
^^^Lee,when you turn the key and that motor fires you are qualified to make posts like that..... winkeye
Youth is wasted on the young.
Post Fri Feb 22, 2008 6:01 pm
sounds like a challenge to me Malcolm :twisted:
**BANNED**
Post Fri Feb 22, 2008 6:08 pm
As a married man,I need a hobby in the garage....I do'nt wanna die yet....
Post Fri Feb 22, 2008 6:11 pm
how can there be miesers still?!
it's 250 sheets, sounds good,looks good adds a bit of poke where is the f**king problem. You can't go wrong with it
There must be 100 pages of utter sh!te being spoken
**BANNED**
Post Fri Feb 22, 2008 6:18 pm
Simon13 wrote:how can there be miesers still?!
(yawn)
fuzzy
He who sleeps with "Gingers"
Post Fri Feb 22, 2008 6:24 pm
£250 is a lot of money to some people.not everyone has an easy life like us in the building trade winkeye most just seek re assurance that it is benificial before parting with their hard earned.
some will just like to weigh up the pro's and cons before deciding whether to hold out and save up for a more proven manifold.
personally for me if i was looking for something like this i wouldnt be interested in aesthetics, i want proven performance gains to justify spending the cash.
i think it needs a power run after a proper set up to see the optimum levels of gains that can be had.
Simon
Post Fri Feb 22, 2008 7:54 pm
The whole point of this test was because people weren't happy because the manifold was 'too cheap', and were convinced it would lose power.
The test has been done, it hasn't lost power, but gained, and it's fairly obvious that a quick fiddle with the fuelling, and it's a worthwhile mod.
I've had a chat with Louise, and she's willing to offer these for £200 posted if we can get 10 people together.
ShepsEvo3
Master of go faster
Post Fri Feb 22, 2008 8:01 pm
Simon wrote:The whole point of this test was because people weren't happy because the manifold was 'too cheap', and were convinced it would lose power.
Well said Simon, I feel another 15 page or so thread going on lol.
For £200 POSTED to your door, that is a BARGAIN people! Rush out, buy it, fit it or modify it and fit it. This item does give a gain on whatever chip you have, remap it and it will give you more power with this fitted than without one IMHO. :wink:
M5pilot
Post Sat Feb 23, 2008 12:41 am
£200.......I'll buy one!
I put money on it that people will still be umming and arring still.
march109
Post Sat Feb 23, 2008 12:42 am
I put money on this thread lasting another 2 pages at least.
Demlotcrew
Post Sat Feb 23, 2008 7:18 am
march109 wrote:I put money on this thread lasting another 2 pages at least.
How much? winkeye
Post Sat Feb 23, 2008 11:33 am
Put me down for one also please :)
march109
Post Sat Feb 23, 2008 11:36 am
How much? winkeye
Withought you locking it? :evil:
Onz
Post Sat Feb 23, 2008 4:49 pm
thanks for the effort guys, i think this exhaust is a very worthwhile mod for £200 and produces exactly the same figures as the Magnex, automac and Alpina manifolds. But for those of us who are looking for power what do we get?
There arn't any more BTB2's available and the RD has never been tested in this way?
If you dont have the money to buy one and test it which should the power seekers look for?
fuzzy
Post Sat Feb 23, 2008 4:51 pm
if you dont have the money to buy one then it wont matter.
**BANNED**
Post Sat Feb 23, 2008 4:54 pm
Price just mentioned was the deal I negotiated the other weekend.Just spent the day crawling under the car fitting the mamifold and a new exhaust. The manifold went on with out too much hassle,the header for 1,2and 3(the long one)it's end was a little oval and it needed a squeese in the vice to sort it. On the 'cross over' section there is a fitting for a lamba sensor,searched Lincoln for a blanking plug with no luck yesterday afternoon.The best tip I got from a fast fit place was to use a spark plug and knock the insulater off...off course my stock off old plugs(why do we all keep old plugs?) were all 12mm and I needed a 14mm...I checked the thread with the adaptor from my compression tester and went back to Partco for their cheapest 14mm spark plug.Got the helpfull guy this time who ordered me a blanking plug that I was able to collect at lunchtime today.£3 plus VaT.Made by Walkers,if anyone else is struggling.Like Barry fitting his BTB I had to modify my centre section to one sliding joint,the other clamp one fitted well.I was not impressed with GSF's Bossal exhaust at all,apart from the mod just mentioned,the two pieces would not fit together without extensive fettling to form a pair of sliding joints.For £175 I expected better. Not yet driven the car but it is no noisier than before,if anything the exhaust note is deeper,a bit more bass,or a bit throatier.Oh,to slide the manifold into place I needed to slacken the O/S engine mount right off and jack the engine up.(I used a lump of 4+2 to protect the sump...)
Onz
Post Sat Feb 23, 2008 4:55 pm
:D You are a funny guy!
What I actually said was "If you dont have the money to buy one and test it"
As in do the work and then know for certain which is best.
Post Sat Feb 23, 2008 6:35 pm
Onz wrote:thanks for the effort guys, i think this exhaust is a very worthwhile mod for £200 and produces exactly the same figures as the Magnex, automac and Alpina manifolds. But for those of us who are looking for power what do we get?
an RD one went on Ebay for £350 what a bargain and it adds useful power i promise. Allows the engine to rev much more freely at high rpms
march109
Post Sat Feb 23, 2008 7:08 pm
I know I paid more for my RD one! Still can't wait to fit it. I've been polishing it up alot lately though, just can't help myself. £350 is a bargain.
