Morat
magpie, how many hours labour am I looking at for a rear main seal? Mine is doing a good job of rust proofing the floorpan atm, but I got an advisory for it this time round
a rear crank seal will involve a fair few man hours,it depends which way the mechanic finds the easiest way of attack against the Jerry be it engine lifted and supported with box removal on a ramp which in turn involves removing of anything connected or blocking access .
next mot just get the baby wipes out clean up and go elsewhere unless you have large deposits of Iraqi currency dispensed on your land beneath the tourings evening resting place .
+ a yard full of scrap turds
SHAKEELE30
- Boost Junkie
Nothing at all except fuel it & drive it... battery decided to go flat for a few minutes randomly... but started again...confused me totally
scott180gtb
MoratMorat wrote:and she's BACK!!!
Actually Autohaus dropped her back yesterday but I didn't have chance to test drive until this evening. What a differenceIt was the Blue Temp Sensor after all so it's back to rock steady 750 rpm idle, no hesitation off-idle with full or part throttle. In fact, she's now got a thoroughly modern feeling throttle which I didn't realise the E30 could manage. Awesome. I'm really glad that I've got a proper BMW specialist garage in the area with two Master Techs (or ex-master techs I suppose) who grew up on E30s
\o/
Give us a clue to the location of this garage?
I'm not sure if I have the right one.
Cars
2007 VW Caravelle 2.5 TDI 250 bhp 550 NM
1989 325i Sport Gone
2003 E46 320d Touring
1998 E36 M3 EVO Track Toy
1996 E36 328i Sport welder-up project
any pics ?kieran325 wrote: It needs a good clean now but it looks good dirty
You sick mofoe30topless wrote:any pics ?kieran325 wrote: It needs a good clean now but it looks good dirty
It's parked up in the garage now and I'm off out on the beer for the day, I might take some dirty pics tomorrow for ya.
Morat
Near Wiggingtonscott180gtb wrote:MoratMorat wrote:and she's BACK!!!
\o/
http://www.autohausdiagnostics.co.uk/
They're good guys.
Cloggy Saint
21.7 mpg is still pretty thirsty!Morat wrote:Did about 50 miles today, car ran as sweet as you like. So chuffed. Also, OBC is now showing 21.7 mpg instead of 17.5 - check your blue temp senders folks! I was getting poor mpg long before I had any running issues.
Apologies to people whose economy figures I disbelieved in the past!
Captain_Birdseye
Why check your blue temp sender?
Cloggy Saint
Thirsty indeed, if mine shows anything like that its getting LPGed or sent on its merry way.Cloggy Saint wrote:21.7 mpg is still pretty thirsty!Morat wrote:Did about 50 miles today, car ran as sweet as you like. So chuffed. Also, OBC is now showing 21.7 mpg instead of 17.5 - check your blue temp senders folks! I was getting poor mpg long before I had any running issues.
Raise hell praise Dale.
That's about what my 325i does and both mine and morats have 3.91 ratio diffs.verde wrote:Thirsty indeed, if mine shows anything like that its getting LPGed or sent on its merry way.Cloggy Saint wrote:21.7 mpg is still pretty thirsty!Morat wrote:Did about 50 miles today, car ran as sweet as you like. So chuffed. Also, OBC is now showing 21.7 mpg instead of 17.5 - check your blue temp senders folks! I was getting poor mpg long before I had any running issues.
You would have to mental to lift the engine to replace the rear main seal!magpie wrote:a rear crank seal will involve a fair few man hours,it depends which way the mechanic finds the easiest way of attack against the Jerry be it engine lifted and supported with box removal on a ramp which in turn involves removing of anything connected or blocking access .
Gearbox out every time weather its on the floor or a ramp.
If doing it on a ramp, providing the are no rusty exhaust dramas then about two hours to do a rear main seal on a 325i.
Book time is probably about 3 hours.
Morat
Thanks Barry! I'll have to clean it up a bit and work out if it's the sump or the rear mainand go from there.
- **BANNED**
Drove the touring to Norfolk and back,had an almost clear road going,126 miles in an hour and fifty minutes,usual time is around two and a half hours.
Spent three hours with a power planer playing with the boat!
Youth is wasted on the young.
engine all ready to come out now i seriously forgot how nice and simple these thing are to work on (after my last car mitshi evo 6 ,book says 15-20 hours to change a clutch in one ,i went through 3 in one year got it down to 4.5 hours to change on a ramp) . going to see - Lurch320i - to buy a new engine from him at the weekend ,so hopefully at some point next week i will be able to go for a little first drive out in the e30 see what else need replacing .and start a turbo build on my engine at long last
macas
Wheres the fan speed resistor?...need to replace that on mine.....johnl320 wrote:Changed the fan speed resistor, as i had lost number 1 on the switch. Swapped the fan motor for a freshly lubed up goodun, the old one looked to be the original and was a bit worn after 235k.
behind the glovebox,on the right, tucked into the heater boxmacas wrote:Wheres the fan speed resistor?...need to replace that on mine.....johnl320 wrote:Changed the fan speed resistor, as i had lost number 1 on the switch. Swapped the fan motor for a freshly lubed up goodun, the old one looked to be the original and was a bit worn after 235k.
Cloggy Saint
So much for the 2.0 and 2.5 being as uneconomical as each other then.bss325i wrote:That's about what my 325i does and both mine and morats have 3.91 ratio diffs.verde wrote:Thirsty indeed, if mine shows anything like that its getting LPGed or sent on its merry way.Cloggy Saint wrote: 21.7 mpg is still pretty thirsty!
macas
Why thank you young sir.......johnl320 wrote:behind the glovebox,on the right, tucked into the heater boxmacas wrote:Wheres the fan speed resistor?...need to replace that on mine.....johnl320 wrote:Changed the fan speed resistor, as i had lost number 1 on the switch. Swapped the fan motor for a freshly lubed up goodun, the old one looked to be the original and was a bit worn after 235k.
I've got a lead foot in the E30, 25mpg is possible.Cloggy Saint wrote:So much for the 2.0 and 2.5 being as uneconomical as each other then.bss325i wrote:That's about what my 325i does and both mine and morats have 3.91 ratio diffs.verde wrote: Thirsty indeed, if mine shows anything like that its getting LPGed or sent on its merry way.
Gert_8
- Location: In your back passage faster than a rat up a drainpipe!
I cleaned the engine bay as best I could, before getting bored. The bonnet sliding hook things are silver again!
- aimlessrock
Took the injectors and fuel rail out, injector tip were
black and in a dreadful state, new refurbed once should
be with me and fitted by Saturday.
E30 320i Convertible (1989)
190 Mercedes (1988)
190 Mercedes (1988)
scott180gtb
Yes got them now.Morat wrote:Near Wiggingtonscott180gtb wrote:MoratMorat wrote:and she's BACK!!!
\o/
They're good guys.
I use Tim next door to these lads for my powder coating. He's in the next unit called Yorkvick engineering services.
I never new these lads were good on E30's
I have the same hesitation from idle. Will try the blue sensor!
Cars
Your lucky I did that the other day and one of the injector tip s fell off so I had to take the full inlet off .aimlessrock wrote:Took the injectors and fuel rail out, injector tip were
- aimlessrock
That's a pain, but an ideal chance to clean and paint the inlet!!!sunnysr wrote:Your lucky I did that the other day and one of the injector tip s fell off so I had to take the full inlet off .aimlessrock wrote:Took the injectors and fuel rail out, injector tip were
190 Mercedes (1988)
190 Mercedes (1988)
