Tyres..what do you use?
e301988325i
Fri Sep 05, 2008 5:12 pm
I'm running TOYO T1Rs 205/55/15 good wet or dry, had 2 punctures though :( from www.mytyres.co.uk very usefull, had 4 sets off them now always good service. Have done 10000 miles over 2 years, including 25 dry laps of the nurburgring, and are about 2/3rds worn, open diff and never wheelspinning
For those of you worried about your speedos', the difference between 205/55/15 and 205/50/15 is 3%. ie if your speedo says 100mph you'll be doing 97mph, at 30mph you'll be doing 29.1mph.
It's easy to work out your rolling diameter 3.142 x ( (rim in inches x 25.4) + (2 x tyre width x profile) )
as an example standard 205/55 r15 3.142 x ( (15 x 25.4 ) + (2 x 205 x 0.55 ) ) = 1905.6mm
Checked my speedo on standard wheels against 2 different gps systems and the speedo reads high about 3-4 mph across 0-70mph and gets worse as speed increases, reading 5-6 mph above 100mph, on a private road officer!! exactly the same result on the two E36's I've had as well.
I said:
e30topless said:
lock the wife in there
StuBeeDoo
Fri Sep 05, 2008 5:25 pm
Fushion_Julz wrote:My Toyo T1Rs are getting close to needing replacements on the rear (the fronts are about half-worn)...So I checked last night through my receipts...
They are 15mths old (June 07) and have covered a bit under 15K miles...
Make of that what you will, but I'd say the wear rate wasn't brilliant...
If I get something like that out of my new Toyo's, I'll be well pleased. I don't fancy the idea of tyres that last 3-and-a-half years and 45k miles like my last ones. The side walls are starting to show their age and for my own peace-of-mind I should have changed them 6 months ago, but they've still got 3mm on them. :roll:
I have less of a problem with replacing tyres every 12-18 months than I do with the thought of what could happen due to rubber fatigue.
zimmer-320i wrote:im on 205/55/16's im wondering if im running the right rolling radias, or will a decent set of 215 50 16's be better on the rear and michilen 205/50/16 on the front?
205/50x16 is the one you want. It's as near as you can get to 205/55x15.
Fushion_Julz
Fri Sep 05, 2008 6:00 pm
[/quote] 205/50x16 is the one you want. It's as near as you can get to 205/55x15.[/quote]
Or 225/45/16
1987 Henna Rot M3 (was 195bhp CAT..now more and no cat)
2001 E46 330i SE Touring (manual)
323iNathan
Sat Sep 06, 2008 9:16 am
I had Falkens and they were completely useless in anything worse than a drizzle, alright in the dry.
I now have Dunlop Sport Maxx fitted all round, and they are superb!! It feels like my car is on rails rain or shine.
I can throw my car around in the wet and it just sticks.
My brother has Dunlop SP9000's and they're quite good too, but I'd go with the Sport Maxx over the SP9000's.
