still discovering things!
peejay
Post Sat Feb 24, 2007 10:54 pm
320iSE wrote:It's specifically designed to test the brightness or otherwise of the owners... :wink:
Good point...well made !
:roll:
Life begins at 40 ( to matter!)
bigkev
Post Sat Feb 24, 2007 11:05 pm
took me 2 years to find out i had heated mirrors and i was waisting my time freezing my knackers off scraping the frost in the mornings :o:
handpaper
Post Sun Feb 25, 2007 1:42 am
Jesus325iTouring wrote:Did you know if you look under the plastic interior trim along the transmission tunnel between the gear stick and the dashboard you will probably find your glovebox torch if yours is missing?
And I think I know how it gets there!
What do you suppose happens when you SLAM the glovebox shut (like I do most of the time because it's full of crap)?
Yep, the little torch flies up off the contacts, bounces off the underside of the dash and falls down behind the centre console!
I'll look for mine in the morning....
Jesus325iTouring
Frog freak !
Frog freak !
Post Sun Feb 25, 2007 8:20 am
Sounds like a reasonable description of what happens :D
Is it there? winkeye
gooner1
Out humping Reindeer
Post Sun Feb 25, 2007 8:41 am
Has anyone got a pic of this little white torch in its actual charging position
in the glovebox?. There is a reason im asking this that i really dont want to explain at the moment. :o:
Nelly
Gumbo
Gumbo
Post Sun Feb 25, 2007 8:46 am
Put it in the slot so the the BMW roundal if facing fowards the drivers side :wink:
"I F**KING LOVE YOU GUMBO"
gooner1
Post Sun Feb 25, 2007 8:51 am
Hmmm, what slot mate, thats partly why i need the pic.
noney82
Post Sun Feb 25, 2007 1:21 pm
this what your after
Cotty
Hartge Crew
Post Sun Feb 25, 2007 4:54 pm
Lots of torches found then. :teehee:
