***Wishbones***
Royalratch
Post Thu Jan 11, 2007 11:43 pm
Jeez.
I could have sworn they were rubber.
Mind you, I've only seen the Touring one's.
They rubber?
Post Fri Jan 12, 2007 12:05 am
Jamesb318is wrote:I'm pretty sure the eccentric bushes push the wheels foward in the arch aswell.
Yes, they do push the wheels forward, they have locating notches to stop you putting them in backwards.
Heres that pic again :drool:
Post Fri Jan 12, 2007 12:58 am
Royalratch wrote:Jeez.
They rubber?
???? All the ball joints I've ever seen have been made of metal. May be a bit of plastic in the cup, but the actual balls have always been 100% steel.
Chris-W
Post Fri Jan 12, 2007 9:40 am
I'm just trying to imagine the handling characteristics of a car with rubber ball joints.....
Demlotcrew
Post Fri Jan 12, 2007 10:14 am
Royalratch wrote:£200 is no joke for each arm either. I can't believe BMW would make them and not make the rubber replaceable? Are the alloy arms supposed to only last the life of the rubber, like proper Motorsport parts?
I use these arms on my car and when it comes time to replace them im quite happy to part with £200 a pop.
The arms BMW use are far from problematic or have any fatigue issues. In fact they are just as strong as the late E36 M3 arms! Ie all ball joints are heat treated and the alloy is forged. (they dont heat up or cool down either) :mad:
Andrew
Royalratch
Post Fri Jan 12, 2007 10:19 am
They rubber?
I thought you meant that even the rubber surrounding was metal on M3's.
I knew they were steel at the joint.:D
Demlotcrew
Post Fri Jan 12, 2007 10:27 am
Royalratch wrote:I can't believe BMW would make them and not make the rubber replaceable? Are the alloy arms supposed to only last the life of the rubber, like proper Motorsport parts?
Royalratch wrote:I thought you meant that even the rubber surrounding was metal on M3's.
Where have you seen any rubber on 'proper' motorsport parts 8O
Royalratch
Post Fri Jan 12, 2007 10:42 am
See above.
Demlotcrew
Post Fri Jan 12, 2007 10:46 am
im looking???? but cant see anything motorsport. :?
Unless you think that BMW used these alloy arms in their DTM/Group A/N race cars?
Andrew
Royalratch
Post Fri Jan 12, 2007 10:53 am
What I thought Brian said was that the M3 uses all 'steel' joints with NO rubber surround, not even as the bush that controls play. A solid steel ball. I now understand what he meant.
Or are you looking for an argument?
Chill - nobody is questioning you.
stuartgallafant
Post Fri Jan 12, 2007 11:28 am
those wishbones look cool man!!! i want some
BIGJO
Post Fri Jan 12, 2007 2:15 pm
Royalratch, what wishbones are they? Thanks for your input as well fella :thumb:
Regards, BJ.
stuartgallafant
Post Fri Jan 12, 2007 3:02 pm
jo, i think they are the E36 M3 evo ones, but im not sure...
Royalratch
Post Fri Jan 12, 2007 3:12 pm
They're E30 M3 wishbones - that's what the supplier lists them as.
As you can see, the balljoints are still rubber (I know the actual ball coupling inside is steel).
I thought people were saying that that even the rubber bit's are metal on these which is why I was confused.
This US supplier lists them for $237 each (£121) which is almost half price. They are OEM too.
http://www.vacmotorsports.com/cgi-bin/v ... tem_id=331
If any of you guys want them, I have a quite a few buds in the US who will take delivery of them and forward them here.
Or, the store may sell you them directly but shipping and import duty will ruin the bargain a bit.
I know how to dodge import tax tho, I hardly buy anything major in the UK anymore.
Let me know - if my buddies deal with it they will forward them for free and waive the tax.
I wouldn't bother unless it's for an M3 to be honest tho...
stuartgallafant
Post Fri Jan 12, 2007 3:56 pm
that is still a schocking amount of money for 1 arm though!
:cry: i really want these too!!
jpboost
Post Fri Jan 12, 2007 4:12 pm
stuartgallafant wrote:that is still a schocking amount of money for 1 arm though!
I did hear of them being availabe in the uk for aroun £160+ the vat. It is a lot of moeny though, especially if you consider that many people replace these as a service item. There were some instances of ally arms cracking on some track cars in the states. Since then, plenty of people started changing them over reguarly. (every year or 2)
Quite a few m3 people run steel ones on their track cars due to the huge price difference(and still change them regularly)
Royalratch
Post Fri Jan 12, 2007 6:07 pm
If I had an M3, I would fit them. I think all M cars really should be respected and fit with OE parts.
Otherwise what's the point of having one? I mean, you should only run tehse cars if you can afford too.
It is mad dollars to run tho that's true...
BIGJO
Post Fri Jan 12, 2007 6:14 pm
What would be the best wishbones for a Sport anyone?
Regards, BJ.
Royalratch
Post Fri Jan 12, 2007 6:18 pm
BMW one's.
If they're too expensive - Lemfoerder.
Get solid bracket bushes but non-eccentric.
buster
Post Fri Jan 12, 2007 6:23 pm
id go for the eccentric genuine m3 bushes personally.I've seen the ones at c3 ,i think they were £58.
Better high speed stability and better self centre of the steering due to more caster and a bit more negative camber.
Royalratch
Post Fri Jan 12, 2007 6:40 pm
S'all good.:D
BIGJO
Post Fri Jan 12, 2007 7:02 pm
Non-eccentric? I've ordered eccentric Powerflex bushes :?
Regards, BJ.
old_skool
Post Fri Jan 12, 2007 7:03 pm
:drool:
I hope that's what the underside of my touring is gonna look like winkeye
Sorry, off topic I know :o:
Nice pic Dan, whose car is that?
Chris-W
Post Fri Jan 12, 2007 7:05 pm
So clean, they covered the lift pads with gloves.
320Touring
Post Fri Jan 12, 2007 7:07 pm
Chris-W wrote:So clean, they covered the lift pads with gloves.
luckily photo's are silent,so you cant hear the apprentice's scream!
old_skool
Post Fri Jan 12, 2007 7:17 pm
I noticed that too. Don't all good garages do that :teehee:
Post Fri Jan 12, 2007 7:31 pm
Thats the bubble M3 :D
Simon
Post Fri Jan 12, 2007 7:33 pm
old_skool_2002 wrote:Image
:drool:
http://www.bimmers.com/gallery/bubble-car
It got sold to a guy who used it as a track car in the end! 8O
Post Fri Jan 12, 2007 7:35 pm
Looking at that picture has got me thinking, has anyone got one of those gearbox supports? That might be just what im after :D
Post Fri Jan 12, 2007 8:16 pm
Royalratch wrote:They're E30 M3 wishbones
and 325 touring E30.
Royalratch
Post Fri Jan 12, 2007 9:37 pm
That bubbble car is insane! Is it new?
You can buy those bubbles from Frosts.
They're airtight but I think you can also contolr the temperature.
BIGJO
Post Fri Jan 12, 2007 9:53 pm
Anyone know the difference between eccentric & non-eccentric bushes?
Regards, BJ.
it's been explained or can't you read?
BIGJO
Post Fri Jan 12, 2007 9:58 pm
BIGJO
Post Fri Jan 12, 2007 10:02 pm
I can't read Si, can anyone help me out? Sign language or any other method of explaining would be great seeing as I can't read!
Eccentric & non-eccentric please, thanks.
Regards, BJ.
