Isn`t This Koooool More BHP for Pennies
Globulator
Post Sat Oct 07, 2006 9:17 am
GDBN wrote:So now you know there's more than a couple of hundred complete arseholes in the world!
Ironic - but the best free power increase (including free economy boost and long engine life) appears to be by driving that new engined car like a complete tit - to ensure you achieve a good ring seal (fnaar fnaar) and don't mash the cams 8O .
Could be the demonstrator car ends up with the best engine - thanks to all the arseholes thraping it properly...
winkeye
http://mototuneusa.com/circular_logic.htm
http://www.cutestudio.net/doku.php?id=cars:running_in
1986 325i 'vert, funk louder than standard.
"No Mr Bond, I expect you to tell me why your 4 litre, 282bhp sports car can't outrun some lardy old Mercs.."
Audio & electronic software: http://www.cutestudio.net
gareth
Post Sat Oct 07, 2006 11:03 am
it can't be long now before you can get the "NEON-POWER-CHIP-RESISTOR"!!!!!!!!! in fact i might sell some. a bit more expensive though, a LED with integral ballast resistor! i can even buy flashing ones for about 30p, they are capable of adding 50bhp per flash!
Tarmac-Terrorist
Post Sat Oct 07, 2006 10:39 pm
Just been going through his feedback, (yes i'm very bored lol) Thers some realidiots out there!!!
put this mod on ended up calling the rac!!!!!!!!!!!! not a happy bunny
Buyer johnboyinc2006( 4 ) 05-Aug-06 16:31 250012396227
--alpina--
Post Sat Oct 07, 2006 10:45 pm
Comments :
doesn work as stated just uses more fuel and found that they only 25p frm maplin
Buyer gaz19780_0( 253) 22-Aug-06 17:57 250015306112
Reply by performance-mod: These Modules Are More Then You Think!! Money Back Guarantee, If Not Satisfied?? 22-Aug-06 20:24
Rating Mutually Withdrawn: Buyer and seller mutually agreed to withdraw feedback for this item. Learn more. 31-Aug-06 19:15
e36boy
Post Sat Oct 07, 2006 11:03 pm
Yeah you've gotta be warey of things like this, They promise big power increases but only want Ԛ£3.99, I think anyone with half a brain would keep well away from these sort of adds. :mad:
fuzzy
He who sleeps with "Gingers"
Post Sun Oct 08, 2006 12:57 pm
jmc330i wrote:
dazleeds wrote:apperently you can gain some by putting the rear seats flat :mad:
That was classic :lol:
ill bet that muppet still takes abuse over that one :mad:
fuzzy
Post Sun Oct 08, 2006 1:02 pm
Brianmoooore wrote:Adding this resistor is the same as having a faulty blue engine temperature sensor. The ECU thinks the engine hasn't fully warmed up so raises the idle speed a little and over fuels the engine to compensate for petrol vapour condensing out on cold metal combustion chambers and cylinder walls.
Most ECUs run the engine on the lean side of the mixture which gives maximum power for reasons of efficiency and emissions, so enriching the mixture a little will give a marginal power increase at the expense of greater fuel consumption, engine wear and oil contamination.
i remember reading somewhere that in extreme cases fuel mix had become so rich as to have caused bore wash and engine failure.
Post Sun Oct 08, 2006 1:36 pm
fuzzy wrote: i remember reading somewhere that in extreme cases fuel mix had become so rich as to have caused bore wash and engine failure.
It will
Post Sun Oct 08, 2006 1:38 pm
fuzzy wrote:
It would lower the centre of gravity slightly, and thus improve the handling.
Effect might be extremely marginal, but it's the sort of thing they'd spend Ԛ£10,000s on in F1.
