So which alloy wheel size REALLY is the best..
Rosc0PColtrane
Post Sat Jul 15, 2006 2:41 pm
jaistanley wrote:The reason the cars handle best on 15"s (or indeed the wheel they were designed to run on) and not aftermarket wheels is that certain geometries are programmed in.
The king pin inclination is the angle of the centre of the wheels effective contact patch to the pivot point of the top of the McPhereson strut. This and the slip angle of the tyre determine the dynamic camber and castor of the wheel.
If you choose the offset, width and tyre profile correctly you can reduce adverse effects. Smaller profile tyres, to a point, can improve the feel of a car but has two nock on effects. The slip angle of the tyre is reduced and on rough surfaces has less compliance so don't deform to maintain grip.
Changing diameters widths and profiles also changes the shape of a tyres contact patch. Different shapes exibit different characteristics of grip and camber thrust.
The cumulative effect of the above are the symptoms you describe. 'Not feeling right'. Rather than go into detail (and have to look stuff up in uni notes - quit while you're ahead!) I'll leave it at that!
Touring car wheels were massive to accomodate massive brakes and reduce tyre temperatures and pit stops (wear).
Jai
magic!
Just what i was after!!
So surely by keeping 15's and lowering the car, this would also have a similar adverse effect as you are changing the standard geometricies that the car was inherited with?
Also in chosing aftermarket wheels, consideration has to be given to changing the suspension set up of compensate the adverse characteristics of aftermarket wheels (or just drive slower)?
After reading your post, I would question whether touring cars larger wheels are a response to improved grip. As you said, the tyre will not deform to maintain grip and this surely will put an increased stress on the rubber, causing greater wear? I suppose this is offset by having big tyre widths?
Formula 1 technology braking has also demonstrated that immense braking power is possible without supersized brakes?
It's probably not a fair comparison as Touring car have completely different suspension set ups which are a conclusion of heavy investment, testing and some fecking clever people.
We have our mates opinion and mass market plug and play alternatives!!
Post Sat Jul 15, 2006 4:12 pm
but F1 brakes are limited in size by the FIA.. if they could go bigger they would
Demlotcrew
Post Sun Jul 16, 2006 9:15 am
We are comparing a 20+ year old design of car to a F1 racer
Andrew
TommyC
Post Sun Jul 16, 2006 1:00 pm
Demlotcrew wrote: We are comparing a 20+ year old design of car to a F1 racer
Yeah, but the theory is still the same!!! I'm surprised you've swapped your wheels from standard, i would've thought yours work better than after market ones.......
blatantarrogance wrote: Same with rally. On tarmac stages (normal roads) they tend to use huge alloys, saving the smaller sizes obviusly for the more gruelling surfaces.
Obviously the smaller sizes can assist with dampening characteristics of cars but the rally example to me is good evidence for the larger wheel sizes being used on similar roads to our very own e30's?
In the instance of rally cars, smaller wheels (15's) are used on gravel stages because you actually need a smaller contact patch with the road surface. Gravel tyres are designed to bite down through the loose stuff on the surface, sweep it out of the way, and get down to the hard packed stuff underneath (i'm sure some dynamic friction principles come into it too). Thats why they kick up so much gravel and dust when they fly down the stages.
(it get's to the gravel stuff half way throught the clip)
http://video.google.com/videoplay?docid ... ttro+rally
(hows about that for some proper drifting then??)
(some fancy foot work)
http://video.google.com/videoplay?docid ... oup+b+audi
They use 17-18" wheels on tarmac so they can have more grip and fit bigger brakes. Obviously they change the suspension geometry too, to dial out the negative effects of fitting the bigger wheels.
http://video.google.com/videoplay?docid ... W+M3+rally
When it's upside down and burning, you've gone too FAST!!!
Post Sun Jul 16, 2006 4:50 pm
He's running Hartge rims.. hardly some cheap aftermarket rubbish..
Cotty
Hartge Crew
Post Sun Jul 16, 2006 5:49 pm
Jhonno wrote:He's running Hartge rims.. hardly some cheap aftermarket rubbish..
Top rims in my opinion, just fitted my 15" yesterday
Demlotcrew
Post Sun Jul 16, 2006 7:44 pm
I have tried most of the wheels made for the E30 and just out of function before fashion i have gone with the 16" hartges and yup they are hardly cheap aftermarket rubbish!
Andrew
Cotty
Hartge Crew
Post Sun Jul 16, 2006 8:00 pm
say that again it didnt catch it LOL
Cotty
Hartge Crew
Post Sun Jul 16, 2006 8:02 pm
Demlotcrew wrote: I have tried most of the wheels made for the E30 and just out of function before fashion i have gone with the 16" hartges and yup they are hardly cheap aftermarket rubbish!
Andrew
Do you think the Hartge's are lighter than original BBS wheels. I swapped from BBS to Hartge yesterday and the tourer feels like it wants to GO lot more pickup, like there is less unsprung weight
Demlotcrew
Post Sun Jul 16, 2006 8:31 pm
Yup they are lighter.
Had a few beers so maybe thats why you dont get me?
Andrew
Cotty
Hartge Crew
Post Sun Jul 16, 2006 8:34 pm
Andrew
You posted three times, well thats what I saw but then again I have been drinking as well
Morat
Post Mon Jul 17, 2006 9:53 am
Damn, I think the price of 15" BBS is about to go up... c'mon graham cab, get your car back from the bodyshop!! :) 8)
