Lightened flywheel ?
Fit or flog ?
Poll ended at Wed Jul 12, 2006 5:27 pm
Fit it
15
83%
Flog it
3
17%
Total votes: 18
Templ8e30
Post Fri Jul 07, 2006 3:00 pm
The original weight was just under 9Kg, there's quite a bit of bulk on the back of the flywheel that's been taken off but it doesn't actually look much different.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
WillG
Post Fri Jul 07, 2006 3:50 pm
bin it imo if your not 110% sure it wont break, cant be worth the risk of damaging your self or someone else over abit of response
MikeeMiracle
Post Fri Jul 07, 2006 3:58 pm
So long as the person removing the extra material is experienced enough to know where it is safe to remove material from you should be fine.
You'll probably saved a few tenths off the 0-60 time 8)
Red 318is
Take me to the land of the twisty's :)
