You bringing the 'Pina to the Ring then Chap? Or the SE Sportomatic??
Alpina question already/ few pictures of it too!
MaasterBates
No matter Si. You can still look like Da Man by relocating to South Wales, buying a black 4 door 320i on the F plate and doing lots of wheelspins outside the Ace as everyone laughs at/ignores you.
i would love to take the alpina but the engine is barely run in from the rebuild!
auto has suspect steering, would be laugh though, it's like a boat on wheels the dampers are so f**ked
so leaves the trusty sport-will be the most fun as she is set up nicely for it!
think this pina will have stay at home until i can cleanse it of all the council parts that are on it. Then i can take it out without a K&N cone induction roar
MaasterBates
I thought you'd sold the Sport?
i have it's next door now! literally, my bro in law has it now. He is coming on our trip in march. So we will take that, it's the best car for the job out of the 3
Ziggy
Demlotcrew
^ all done.
O/T but what does LGT stand for?
Andrew
Andrew
Ziggy
Did ya just swap it for him?! Wonder how long it'll take him to notice!Demlotcrew wrote:^ all done.
Andrew
Demlotcrew
Yup i sure did.
Andrew
Andrew
Ziggy
Le Grande Testicule?!
Grantley
Car looks very nice, I'd leave the stripes off the car looks clean and uncluttered and black has gotta be one of the best colours !
ho ho ho! thats well good ziggy!
looks like kermit is staying for a while longer!
wicked! i've just insured it!
So now i can get WLN to tax it, so now i can just go up there and collect it and drive it home
so i can bring it out to play at a few meets this summer! Well chuffed, i want to go up there now!!!
Kedge
Awesome news Si, can't wait to see it some point in the summer
Take it the sports no longer getting a 'pina snow plow now then?
nope
if i was a naughty boy. i'd put the cow catcher and engine in my old sport he he. Would be a nice car to me. But i can't do this as it would be a cardinal sin!
But i have to start again somewhat on this car, i need leathers and to add some factory options she has nothing! Half the fun though
12 button obc, leccy sunroof, sport seats cloth, thats it!
Dan318-is
Are the billies going on this?Simon13 wrote:nope![]()
good news on the insurance front!
Alpina's had them also fitted from new and they are still on there! so i'll have 8
M5pilot
Alpina will have the 52mm inserts - doesnt your sport have the 45mm ones with the collar to fit the 52mm struts?
You better also totally avoid speed humps if your intending to keep the cowcatcher on there.
Dan318-is
.Simon13 wrote:Alpina's had them also fitted from new and they are still on there! so i'll have 8
Il buy four!
no my sport has the big boy 51's
Thats a shame my road has speed humps on it, but the sport is fine on them if u go s l o w Cowcatcher on it is a bit doggy ne way
Dan NO! well not yet ne way, vultures leave me be!
M5pilot
51mm....Simon13 wrote:no my sport has the big boy 51's
I was having a talk with Demlot the other day and he said the 51mm ones were the wrong ones....apparently they are too long or something???
I rememeber taking out my old alpina units and replacing them with the ones you have and they were the same height.
Demlotcrew
Si,
Sal is correct to an extent.
There are two types of Inverted bilstiens;
Ones for stock ride heigh springs (might have been fitted to the alpina sal had, but would have been the wrong ones)
Ones for lowered higher spring rate springs (these are the ones you have, they are 1" shorter)
HTH
Andrew
HTH
Andrew
Ant
- Retired Team Member
The Bilsteins that came out of the Alpina had an Alpina engraving on them and were exactly the same height as the Bilstein Sports that Sal was replacing them with.
I know as I changed them.
Do you really want to argue with me on this?
Email FTW
Demlotcrew
I dont want to argue with you full stop!
I have the origional Alpina Parts Cat and it clearly shows the Bilstien damper being the shorter one. Now going by the alpina part numbers you can clearly work out that the early Mtech one cars shared the same size and style of bilstein inverted damper on the front because of the collar nut.
From the pic on the parts cat from alpina you can clearly see its the smaller shock as the taller (also slightly thicker one) has a different shape it at the bottom and the pic shown on the cat is of a live item (not a drawing) and its the shorter one.
Anyway it doesnt matter they are both very good dampers the slight advantage of the longer one is its slightly more heavy duty, thats it!
Still better than the boge gas dampers supplied with the Cup kits.
Andrew
Andrew
M5pilot
Why the need to mention they are better than the Cup kit shocks??
And who says they are Boge?
Your head is really getting too big Andrew thinking you are the expert on everything......because your so not!
Learn to change brake pads properly and not fit second hand engine mounts to my car and I might even think of taking you seriously again.
bullsh!t Sal andrew would not do that. I know your baiting by that comment
Andy knows his stuff, bring this turd on monday and show me his bad workmanship.
Your not going to give him a bad name because he has worked on so many zoners car with excellent results. These people won't believe u either.
Imagine if we started bad mouthing u and your precious reputation?!
Bang out of line
Bang out of line
M5pilot
Listen Kermit,
your best friends with Andy so your obvioulsy going to take his side - understandable.
I asked Demlot to come over and do my car because of his "legendry reputation". Very nice of him but he messed it up and I had to tell him how to change brake pads properly.
The cup kit shocks comment was blatant bait to me trying to wind me up and you also do the same to some extent.
And my Touring is a turd now is it? I can never slate off someone else's pride and joy - I think thats a bit bang out of line. I could say alot about that C2 you just bought but because its such a low thing to do I wont go there. I have ethics and I dont have double standards unlike some.
I dont have to show you his workmanship - it was others who pointed it out! I didnt even check.
My reason for posting about this is not to harm his reputation and I know it wont.
You have blatantly tried in the past to go out and affect my reputation for your own reasons - that never made a difference.
Ant
now now ladies, we all have our reputations to defend !
I know and respect you all , but this is stuff not for the forum en masse, this is a discussion best carried out in private OK
Moderator mode enabled- nuff said already,,,,,
Email FTW
