Strutt braces (are they worth it?)
mrLEE30
Post Mon Dec 19, 2005 3:28 am
Chaos Posted: Sat Dec 17, 2005 7:49 pm Post subject:
mrLEE30 wrote:
cabs must just be thicker, i know that cause i tried putting a coupe dash in a cab and it wouldn't fit (four fckin hours of pi55in about) then i had to cut about two inches off each end.
the windscreens are the same.
windscreen may be the same but the horizontal strut running accross the bottom of the windscreen is thicker, i had to cut about 2-3 inches from each side of the dash just below the metal mounting tabs
