E30 24v VS E30 M3
Post Sat Jun 22, 2013 8:58 pm
The_Diddler wrote:
pacerpete wrote:Beware of a strange brummie bearing Chicken tikka ! Luckily I had been warned so I survived Santa Pod anus intactus :)
You were lucky kiwi boy, if topless wasnt in the caravan you would have being chewing the beige velour upholstery face-down.......
Fess up Paul, the caravan did not go the pearly gates of Billing Aquadrome in the sky due to structural issues it was because it was deemed a biohazard and confiscated by the operation Yewtree feds ! :(
Does that mean we all get to 'sleep ' with Rav and his Tranny ? :D
Fastroad
Post Sat Jun 22, 2013 9:23 pm
pacerpete wrote: Does that mean we all get to 'sleep ' with Rav and his Tranny ? :D
You will have to bring your amps and subs
Post Sun Jun 23, 2013 2:47 am
You Foooking coont, you KIWI tit!!!!!I had my :D tent in there too!!!
jon-m42
Post Sun Jun 23, 2013 11:01 am
The e30 M3 is a legendry motor vehicle with much history and quality.
It should not really be compared to cars of this era as the technology used back then has moved miles apart from good to much better.
anybody know the 1/4 mile times for a totally standard stock e30 m3?
The M52 we all have to understand has 2 more cylinders and has greater yet better technology used with the build. a stronger yet more powerful engine which in turn will always have the upper hand to an S14 engine if trying to compare performance.
I presume the M52 will be better for long motorway cruising with the added better mpg, driving hard in town and on track.
However i am certain doing all that with an M3 the fun factor shoots through the roof, the enjoyment it gives you makes you forget about the M52;s power advantage.
Demlotcrew
Post Sun Jun 23, 2013 11:21 am
The M52 has no power advantage, nor is it a stronger engine and I can assure you it's no where near as economical.
I think people should really get these anecdotal ideals of the M52 out of their head, it's a cheap mass produced engine that has no scope for power other than forced induction.
andyp
True Old Skooler
Post Sun Jun 23, 2013 11:24 am
Demlotcrew wrote:The M52 has no power advantage, nor is it a stronger engine and I can assure you it's no where near as economical.
BUTT it has 6 cylinders a proper bmw engine
jon-m42
Post Sun Jun 23, 2013 11:50 am
Demlotcrew - My knowledge about the S14 engine is rather minimal and i am still learnign about it all as with the M52.
Why is it that the S14 is the better engine in this instance against the M52?
Both engines were mass produced the S14 more predominantly for the racing industry i.e. rally and so on
the M52 was mass produced for your general market non racing.
Surely the 6 cylinder has more power grunt and many tuning options.
The 4 cylinder i presume has a little less grunt however a more is quicker to rev to the limits.
I just would have thought that any and most 6 cylinder due to its engineering would have naturally been more powerful then a 4 cylinder engine.
I read up somewhere a revy engine is not always a fast engine. Could this be the case in with the S14 VS M52?
:roll:
harry_p
Post Sun Jun 23, 2013 11:58 am
The number of cylinders has little to do with power.
In fact, given the same capacity, a four cylinder engine will often make more power because it will need fewer crank bearings to support the extra cylinders, and will have less frictional loss from the cylinders, less valve springs to opperate, less rotating mass etc
cheers,
harry
jon-m42
Post Sun Jun 23, 2013 4:59 pm
since my years in driving i must admit every 4 cylinder car i have driven since 1985 till now to compare with the 6 cylinder cars have to date has always been much smoother.
the overall drive quality and power you feel under the foot on the pedal the 6 cylinder for me has always been like beasty and some have been slugish but all have felt much more powerful then every 4 cylinder cars i have driven.
I may have driven the wrong 4 Cylinder cars in my time i do not know.
Only if BMW could bring back an E30 M3 anniversary edition keeping the shell and interior set up with the added new technology of engine and drive train.. this im sure would be sex on wheels
ajay
Post Sun Jun 23, 2013 5:33 pm
Was the e30 m3 not the first NA bmw engine to hit the 100 BHP per litre ( i know not all quite made that figure)? Calculated that way compare the M52's 2.8ltr against its 193BHP then you'll see the pedigree!
Demlotcrew
Post Wed Jun 26, 2013 7:25 pm
jon-m42 wrote:Only if BMW could bring back an E30 M3 anniversary edition keeping the shell and interior set up with the added new technology of engine and drive train.. this im sure would be sex on wheels
This is something I'm finishing off for a customer, once finished should be exactly what you describe above.
ajay
Post Wed Jun 26, 2013 7:28 pm
POSER! :)
Demlotcrew
Post Wed Jun 26, 2013 7:29 pm
ajay wrote:POSER! :)
Get your photos up, you have some very tasty parts on your car! :wink:
Post Wed Jun 26, 2013 7:40 pm
So what did the 7.5k get the first time around ? :?
jon-m42
Post Wed Jun 26, 2013 7:41 pm
Demlotcrew - this is love lol 8)
ajay
Post Wed Jun 26, 2013 7:43 pm
Im shy,lol! It would probrably frag well i reckon.
jon-m42
Post Wed Jun 26, 2013 8:20 pm
what do you mean by frag ?
ajay
Post Wed Jun 26, 2013 9:01 pm
IE :strip for parts only! Plenty of it goes on here.
Demlotcrew
Post Thu Jun 27, 2013 10:48 am
pacerpete wrote:So what did the 7.5k get the first time around ? :?
A concept :D
Post Thu Jun 27, 2013 10:49 am
A concept :D
Washers and cable ties, innit :(
Demlotcrew
Post Thu Jun 27, 2013 10:50 am
:teehee:
Kos
Post Thu Jun 27, 2013 4:57 pm
pacerpete wrote:
A concept :D
Because Motorsport :P
pony
Post Thu Jun 27, 2013 11:23 pm
That is sex on wheels
How much does it cost to get S54B32 conversion for E30 :-) ?
7.5 ?
Post Fri Jun 28, 2013 10:33 am
pony wrote:
pacerpete wrote:
Demlotcrew wrote: This is something I'm finishing off for a customer, once finished should be exactly what you describe above.
7.5 ?
In this instance, 7.5k got an engine resting in the bay and an assortment of low rent bodges and 'interesting' engineering solutions :(
Fastroad
Post Fri Jun 28, 2013 11:11 am
I wonder what the solutions are, for 7.5k I would need a factory solution considering you could buy a few extra sports for that money
HairyScreech
Post Sun Jun 30, 2013 5:47 pm
5.5k has built an s50 e36 compact for track use with most of the labor paid for in bmw parts.
7.5k would only maybe cover an s54 conversion if you had the car and the s54 already.
Putting these motors into cars they were not intended for and doing it to any decent standard is expensive.
maxfield
Post Sun Jun 30, 2013 6:03 pm
HairyScreech wrote:5.5k has built an s50 e36 compact for track use with most of the labor paid for in bmw parts.
I've seen sooo many engine conversions and some of the work I've seen is horrible.
I'm sure pacer will back me up as he's seen some work from a lad from around here.
People don't realise the expensive and time it takes to do this properly.
Andyboy
Alpina Colada
Post Sun Jun 30, 2013 6:12 pm
7.5 ?
Turkish spec?
Post Sun Jun 30, 2013 6:58 pm
Andyboy wrote:
7.5 ?
Turkish spec?
LOL :mad:
Fastroad
Post Sun Jun 30, 2013 10:53 pm
Andyboy wrote:
7.5 ?
Turkish spec?
Is this because they used the old washer bottle???
dusty23
Post Sun Jun 30, 2013 11:05 pm
I think its in reference to a fella that 'builds' these conversions, but I could be wrong.
1988 M3 lachs silver S50B32
1989 325i sport delphin grey
1993 316i lux touring lazur blue
dusty23
Post Sun Jun 30, 2013 11:09 pm
Here is how it should look, all credit goes to beardymat.
Not an S54 but still...
Image[/img]
jon-m42
Post Mon Jul 01, 2013 8:53 am
This is where expensive dreams come true with the help of you all here on the zone. Both these beasty straigh 6 engines suit and look well at home in the bays.
Only if eh.. How much would his tye of conversion cost Parts, Labbor? :mad:
dusty23
Post Mon Jul 01, 2013 9:05 am
jon-m42 wrote:How much would his tye of conversion cost Parts, Labbor? :mad:
Its been discussed a lot, these engines are coming down in price a bit but I would say around 6k mark if you did the majority of it yourself, thats s50 not sure about s54 but probably not a lot more, again this is doing the work yourself.
Demlotcrew
Post Mon Jul 01, 2013 9:14 am
If I was doing this conversion now, I would skip the S50 and fit the S54. But I can say the S54 install is significantly more expensive.
