Whats this on my HT leads?
Post Tue Apr 10, 2012 9:29 am
Not 'a load more fuel', no, but it will use some more, and the engine will run that little bit less well than it otherwise would.
PeteE30Tourer
Post Tue Apr 10, 2012 12:35 pm
Brianmoooore wrote:Not 'a load more fuel', no, but it will use some more, and the engine will run that little bit less well than it otherwise would.
But surely if it's squirting fuel from all 6 injectors when it should only be squirting on 3, that's twice as much fuel being used, albeit only under certain circumstances. I'm not questioning your advice and vastly superior knowledge here Brian, I'm just keen to understand how this works.
Back behind an M20, but now I can hear it better.
cecotto479
Caution Unreliable Seller
Post Tue Apr 10, 2012 12:47 pm
It's operating in milliseconds. Very, very little fuel will be wasted. It'll be sucked in an a millisecond or so when it's its turn to be compressed.
Back to the 1.1/1.3 thing. I suppose that's the difference between what I thought were interchangeable 1.3 ECUs. The 173 will be 1.1 while the 380 will be 1.3?
1981 E23 735i
Post Tue Apr 10, 2012 1:24 pm
Injectors are pulse width modulated - the ECU varies the time they are open for. When it fires all six together, it opens them for half the time. The ECU changes to firing them all the time at times of high fuel demand anyway, as three at a time can't flow enough fuel for WOT.
173 and 380 ECUs are both M1.3. The 380 is a newer (but not necessarily better!) version.
cecotto479
Post Tue Apr 10, 2012 2:42 pm
So what's the equivalent 1.1 ECU then?
M1.0 is the 073 and M1.3 is 380. Is it just coincidence that the version number
(".0" and ".3") are the same as the third last digit in the ECU number?
If this theory stands up, it would fit with 173 being the M1.1 ECU. Or just a coincidence.
1981 E23 735i
Post Wed Apr 11, 2012 9:16 am
Lists I have all show a 153 as being M1.1, and a 154 as being for the 'e' version.
