Project Trailer/BBQ
skipunda
Post Sat Oct 22, 2011 10:45 am
Something different, Subscribed.
Chris
Jim320i
E30 Zone News / COTM Team
Post Sat Oct 22, 2011 10:47 am
Not you Malc :thumb: It was aimed at B7. Anyway, pointless in ruining a thread I only just started...
**BANNED**
Post Sat Oct 22, 2011 11:00 am
Perhaps you could mount the barbie unit in a box,and arrange the box to lift up out of the boot and roll backwards?
This would take the heat source away from both the wiring and the plastic bits...
Youth is wasted on the young.
Kedge
Post Sat Oct 22, 2011 11:12 am
Or what about cutting away a lot of the floor and then making somekind of frame structure to support what ever you plan on using to cook on, could that help prevent heat transfering to the things that could easily melt? You could also line everything with some kind of heat resistant foam.
Instagram - Kedge85
Jim320i
Post Sat Oct 22, 2011 1:56 pm
Might be worth looking into Kedge as it would also help on reducing the weight of the thing too.
The heat restiant foam is worth looking into as I will have the bbq section seperate from the actual lining of the boot anyway so if I incase it all away and 'floating' then heat insulate it, we'll be cooking on gas winkeye
bimanut
Post Sat Oct 22, 2011 3:52 pm
Duke137 wrote:You can never hide a towbar completely tbh even the detachable type
I'm not sure about this project if I'm honest mate, though I admire your efforts.
Did you get my text about the Blaupunkt radio?
The oe e30 tow bars are completly hidden behind the bumber and the electric hook up tilts up behind the bumber when not in use.
I know this because i`ve got one :D cost me about £90 i think.
Nice effort mate.I made a trailer with a 2door and used the doors to blank the front off,just cut,bent and welded them up. 8)
Took too much room up in the garage so weighed it in.
Jim320i
Post Sat Oct 22, 2011 3:58 pm
You got any pictures bimanut? I was thinking of using doors to blank the front as wouild have all the right curves and bends in the right place...
I have the 2 cab doors but they are completely rot free :cry: Didnt want to be chopping them up, but if I come across to rusty ones, I might go down that route.
Pictures would be cool though if you have any.
Post Sat Oct 22, 2011 4:09 pm
Jim320i wrote:
B7 wrote:
daimlerman wrote:Can you not line the area around the BBQ with asbestos,or better still,it's modern equivilant?
Or buy an oil drum.................
I'm gonna start 'shoo'ing' you off soon... Thats me trying to be polite... :? Give up being a c0ck will you? I understand you don't like it but you havent got to throw in stupid comments every few posts, I already know your view... :roll:
FFS get a sense of humour will ya! :roll: You should know a wind up when you see one. If you can't then tough!
I did however (if you've replaced your dummy yet) have a good idea for this. What did you do with the fuel tank?
A 325i tank will just fit in the boot of a convertible, I have done it. cut 2 squares in the top either side for the grills to go on. The bottom is deeper divided by the propshaft space. That would allow you to have a hot side and a cool side to the coals. Hinge it in and out and it keeps it all E30? winkeye
Keep to coals, Gas is for wiimps although I have just this year been persuaded by the wife to go over to gas :?
Personally I'd still go to B&Q though.......... :evil:
Duke137
Post Sat Oct 22, 2011 4:13 pm
Make sure you drain any excess fuel if you use a tank like Trev says....
But I am sure you dripped it dry already winkeye
Kedge
Post Sat Oct 22, 2011 4:14 pm
I've got to say, i do prefer a proper charcoal BBQ instead of a gas powered one, feels so much more proper!
Instagram - Kedge85
Kedge
Post Sat Oct 22, 2011 4:19 pm
Duke137 wrote:Make sure you drain any excess fuel if you use a tank like Trev says....
The tight arse will have had the fumes evaporating into the chromies tank :mad:
Instagram - Kedge85
Post Sat Oct 22, 2011 4:30 pm
Kedge wrote:I've got to say, i do prefer a proper charcoal BBQ instead of a gas powered one, feels so much more proper!
THIS
Gas BBQ's are the height of :gay: - that and Patio heaters
Charcoal and lighter fluid FTW :twisted:
Jim320i
Post Sat Oct 22, 2011 4:32 pm
I prefer coal to gas too but the heat side of things is where the issues are. Gas would be much cleaner and easier to pull off, but you dont get that charcoal taste when eating which makes a bbq what it is.
As for the tank idea, I have a few tanks available to use if need be, the only issue would be emptying it out... Might turn into a pain in the arse after each time I use it.
@Duke - Git :twisted:
My thoughts at the moment are, if I go for Charcoal, which I really really want to, then I would some how make a 'trough' so to speak, suspended in the centre on the boot giving a good gap round the whole thing, apart from the supporting arms... This way it can stay in the boot. This would then need to be hinged so the whole thing could be tipped out of the boot... Lots of runners to control it all then as hinges everywhere will just make it hard to lift out.
It wont take up the whole boot space anyway, I think we will be cutting out the whole middle section (Bench part & back wall that joins the boot) then moving it so the boot space is smaller and the trailer section is bigger. Will also take alot of weight out too as we dont need the inner lining walls where the door cards usually go in etc. But it will mean we need to reenforce it so it doesnt twist.
I was waiting on Ricky to bring the welder with him today but he didnt :roll: Typical. His old man said he could have it but he has yet to take it so might have to find another one as he can be useless 98% of the time :mad:
I might get out there tomorrow to start removing the inner walls etc, should be ok with a little angle grinder with that, the massive saw has gone back and percision is a little hard with that thing. Need to keep the top section in there for the horse shoe though as it seperates the car well and is more original that trying to get a lid on it. :?
Kedge
Post Sat Oct 22, 2011 4:50 pm
If you split a tank on the seam it'd be easy enough to clean. Plus it should have a drainage hole to make it even easier to rinse out!!
Instagram - Kedge85
Jim320i
Post Sat Oct 22, 2011 5:00 pm
Thats true but then its on the large side it will be a hassle finding somewhere for it to sit and be wont easy to get in and out to empty the coals. Plus, If I get some sheet metal and make the coal carries, it will look more presentable rather than the ugly shape of a fuel tank.
corkie
Post Sun Oct 23, 2011 8:43 am
one of these without the legs :D
http://www.hotrodgrills.eu/
e30
Jim320i
Post Sun Oct 23, 2011 9:34 am
Lol, they look proper cheesy though and over priced. I like the idea of smoke coming out though... I was talking to Ricky who is gonna stand and watch while I make it all about it and I said it would be cool to get the smoke to come out of the exhaust :cool:
Bit of bended tube linked up to the backbox should produce this, a fan on the end to suck in and push it through would help... But thats well cheesy.
Got to get loads done before I can start farting about with stupid bits.
Jim320i
Post Thu Dec 22, 2011 8:03 pm
Update so I dont loose this thread...
Currently nothing has happened with the trailer/bbq other than its now full of other car parts :cry:
I've changed the plan slightly with it now and the bbq bit will be going into the front section just due to the plastics and rubbers in the boot etc...
Ricky never got the welder up here sp thats the reason I havent done anything yet.
Soon as I locate a welder which I can borrow, I may well get something done on it.
Sanchez
Post Thu Dec 22, 2011 8:24 pm
Could you hinge the the front(bit made from old doors) of the trailer so it comes down and the BBQ could pull onto that then when hot all away from everything.
Ide like something like this if i had more space.
Jim320i
Post Thu Dec 22, 2011 8:59 pm
Well I was debating on whether to have something at the front or not, but I do have a few spare doors laying around now so may well be a good idea :D I could even have proper handles on either side to open it winkeye
Jim320i
Post Wed Apr 11, 2012 5:00 pm
Small update -
I have been waiting on a friend to sort a welder out since last summer, he hasnt :(
I've kinda lost interest in it now due to the fact not been able to do owt with it :cry:
Thought I would pull it out of the unit today as I was trying to sort though some stuff (I started storage parts in her) so I gave her a quick clean whilst out of the unit to see if I could get bacinto the mood of doing it... Still not sure, so might attempt to sell it, or take off the remaining few bits and weigh it in... :?
Anyway, some pictures... Still the same as before.
Post Wed Apr 11, 2012 5:03 pm
Get on with it Jim, make the BBQ. :cool:
