What are your 0-60 times?
ShepsEvo3
- Master of go faster
At the GTi International at bruntingthorpe last saturday, the quickest 0-60 mph was a mk1 Scrocco which looked fit for the scrappy. 2.5 seconds to 60!!!
www.sabre-tuning.co.uk
rubber_duck89
60 in my 316 you must be joking
G104VHJ......Alpine White 318i Touring.....RIP
So its about 286 bhp right?oze30 wrote:Yeah, just green cotton air filter.bss325i wrote:Is your M60 standard?oze30 wrote:Ive timed mine with a gps and stop watch and it's roughly hi 5 with a 3.15 diff. A 3.9 diff as it strands now is roughly 5.5 ish, but I can't get the traction down!
- gooner1
- Out humping Reindeer
0 to 60 in two years!!!!!! Feck, that is slow Josh.josh-hocking wrote:mine ive owned for 18 months and im still trying to get it 60 but i think its gonna take another 2 years(its hard on a driveway)
Just trying to get an idea of what mine roughly is, pretty much same power at fly but not sure what at wheel power is. Yours probably has more tourque being a V8 though.oze30 wrote:286 bhp and 197lb/ft at the wheelsbss325i wrote:So its about 286 bhp right?oze30 wrote: Yeah, just green cotton air filter.
Hi guys,
I'm clocking 0-60 in about 4sec (low 4's).... but not in my 325. I have a lancia delta integrale which has been tweaked and lightened (a lot).
Currently in the garage... again
which is why I've got the e30!! fast is good but if it doesn't work then about 8 seconds is perfectly adequate and a lot of fun when it rains
Whats yours?bss325i wrote:Just trying to get an idea of what mine roughly is, pretty much same power at fly but not sure what at wheel power is. Yours probably has more tourque being a V8 though.oze30 wrote:286 bhp and 197lb/ft at the wheelsbss325i wrote: So its about 286 bhp right?
march109
- Contact:
S50B30 iirc possibly B32, but pretty sure its the 3.0L weapon.oze30 wrote:Whats yours?bss325i wrote:Just trying to get an idea of what mine roughly is, pretty much same power at fly but not sure what at wheel power is. Yours probably has more tourque being a V8 though.oze30 wrote: 286 bhp and 197lb/ft at the wheels
march109 wrote:S50B30 iirc possibly B32, but pretty sure its the 3.0L weapon.oze30 wrote:Karan would be a better comparison. He's running an SXX engine.bss325i wrote: Just trying to get an idea of what mine roughly is, pretty much same power at fly but not sure what at wheel power is. Yours probably has more tourque being a V8 though.
Whats yours?
Its old_skool's old S50B30 touring, dyno'ed with 283 bhp.oze30 wrote:march109 wrote:oze30 wrote: Karan would be a better comparison. He's running an SXX engine.
Whats yours?
If you've gone up the drag strip and had it timed properly you can use the 1/8 et and 1/8 mph to calculate your 0-60 to a decent accuracy. Using a stopwatch and eyeballing the speedo is useless.
Here's the calulator thingy;
http://www.wallaceracing.com/0-60_equation.php
According to that my 335i did it in 6.0 seconds at the pod where I wasn't getting a great launch. Should be a bit better now as i've changed a fair bit on the car since then.
My E46 320Ci does it in 8 seconds on a gtech (7.9 in the book) you can put that down to my bad driving
The M54B22 has 170bhp (dont recall the torque off the top of my head, not sure on the weight difference to the E30 but I suspect it's heavier
The Sportster but it's got an M20B28 and weights a lot less than an E30. I'm thinking around 5.5, but that estimate was when it was still a 2.5. Not really tried since as the rebuilt engine is still being run in
You had 4.45... I bet that was interesting... Especially 'around town'murran wrote:with the 4.45 diff and 320i box in my 325i id need a change into 4th to make 60. then again i can do good smokey standing starts in second!
- murran
i still have the 4.45! it tops out at 100 mph!
wasnt so bad when it was a 320i, now ive put the 325i in it really shows up how short it is.
e21 killing tyres with e30 325 powerzzz
drifting on the cheap......... www.trampdrift.com
e21zone........ www.bmwe21.net
Karan
according to my slipTheo325 wrote:If you've gone up the drag strip and had it timed properly you can use the 1/8 et and 1/8 mph to calculate your 0-60 to a decent accuracy. Using a stopwatch and eyeballing the speedo is useless.
8.8s
82.25mph
0-60 4.6s
I would hate to try and predict a 0-60 time for my old Sport coz she used to spin her wheels for about 10 seconds before launch.......In 1st, 2nd and even 3rd sometimes
......Well 3rd was when it was wet !
e30bmlover
- Ac Schnitzer prophet
i have the same problem as you except i only spin one wheel at the moment lol roll on next week!e36boy wrote:In 1st, 2nd and even 3rd sometimes
- maxlee
- Contact:
mine is a easy 2~3 days if i tie my colie to the front it can happen alot quicker (2 days max then) but most times we pass a rspca van so have to brake untie the colie quick and just get out and run
Karan
need to meet up in the wet sometime and u should see what its like lol
goes slideways so easy!
needs hydro wand and strong ass diff though
also where did you get the poly diff mount bush from i spied on ure car.... mine is knackered!!
