Madness - what's the alternative?
rh306
Post Fri Apr 20, 2012 7:09 pm
Speedtouch wrote:something with a galvanised chassis and maybe fibreglass or aluminium body, e.g., Lotus Elite/Eclat/Esprit
...pre-Peter Stevens Esprits must be on the way up by now surely... :drool:
polsta
Post Fri Apr 20, 2012 7:30 pm
bss325i wrote:
The two bolt strut top mount shell was used on ALL models up to '83 in time for the A reg then the single bolt strut top shell was used from '83 to '86 again on ALL models.
You could get RS1600i's on Y and A reg so used both Shells.
XR3's only ever used the twin bolt strut top shell as the XR3i replaced it in early '83.
Twin bolt shell XR3i's ie Y reg ones are VERY rare!
Also, Rosso red (the colour of Polstas 1.3 Laser shell) was never available on XR3's or RS1600i's but could be had on late B and C reg XR3i's as it came out in '85 and replaced Sunburst red.
Coincidently with run of the mill E30's, Zinober red replaced Henna in '85.
Zinober is similar to Rosso and Henna similar to sunburst.
Is yours still a 1.3 Carl or have you dropped the XR3 engine in yet?
i dont know anything about the strut tops, only that what the fella said to me who wanted it, neither do i care as it doesnt matter to me does it and is neither as issue for anything
you always seem to have a swipe at the car, any reason ? inve never pretended its something it isnt and i had a sunburst red one myself, very early xr3 were sunburst red, same as only a few were made with a 4 speed box , then they went to injection engines and rosso red and looked exactly the same , same wheels,spoiler,kit
by the way your trying to sound is like its the wrong color for how it looks or a non xr3 color, someone mentioned this on here before, was it you ? and i then put up pics of a mint low milage rosso red xr3 that looked exactly the same
the way you make it sound is like its a mk4 xr3i color with mnk3 styling, thats not the case at all , only difference is a non injection engine
no it had the engine swap last year sometime, and its a cracking little escort
who really cares ? its not a show car and its a little project ive had and is a lovely car for what it is
polsta
Post Fri Apr 20, 2012 7:38 pm
c reg rosso 1986 xr3i mk3 escort
only external difference is the black around the windows, and the red backing to wing mirrors, which il get done next time something is painted
injection engine
heres a B REG one
Dezzy
CR24v it's a lifestyle
Post Fri Apr 20, 2012 7:47 pm
You fitted the 1.6 rattle top yet?
Post Fri Apr 20, 2012 7:53 pm
polsta wrote:i dont know anything about the strut tops,
Clearly.
polsta wrote:you always seem to have a swipe at the car, any reason ? inve never pretended its something it isnt
On more than one occasion you have said its an XR3. It's not, its a 1.3 Laser.
polsta wrote:very early xr3 were sunburst red, same as only a few were made with a 4 speed box
Sunburst was the only red available on XR3's and was also used on XR3i's up to early '85.
4 Speed XR3's were not rare as the 4 speed box was standard on them with the 5 speed being optional all the way through XR3 production.
I had an early '83 Y reg (GGF669Y) 4 speed white XR3 for example.
polsta wrote:then they went to injection engines and rosso red and looked exactly the same , same wheels,spoiler,kit
Yes, when the XR3i replaced the XR3 they did look the same externally with the same kit and wheels etc but Rosso didn't come out till '85 as i said, XR3 production ended in '83 so Rosso was never an XR3 colour.
XR3i yes, XR3 no!
polsta wrote:by the way your trying to sound is like its the wrong color for how it looks or a non xr3 color, someone mentioned this on here before, was it you ? and i then put up pics of a mint low milage rosso red xr3 that looked exactly the same
See above!
polsta wrote:no it had the engine swap last year sometime, and its a cracking little escort
Good to hear it now has an engine.
If you (or others) are going to post then at least try and be accurate.
I'm correcting the mistakes for accuracy.
Post Fri Apr 20, 2012 7:54 pm
polsta wrote:c reg rosso 1986 xr3i mk3 escort
injection engine
heres a B REG one
Well done, you have just confirmed what i have now posted twice that Rosso came out in '85 so only B and C reg XR3i's.
polsta
Post Fri Apr 20, 2012 8:09 pm
bss325i wrote: Well done, you have just confirmed what i have now posted twice that Rosso came out in '85 so only B and C reg XR3i's.
where have i said otherwise, its a c reg shell in a c reg color
its an xr3 re shell in a a latter color which is still exact same styling and looks, bar the injection engine
i call it an xr3 yes, you got a problem with that ? do you think every owner whos ever re shelled an rs1600i in to a different chell would call it a 1.3 popular and not an rs, old ford re shells are a common thing and many many cars have been re shelled, the shells are the same anyway, how many mk1, 2,3 , escorts are out there that have also had the id and number plates swapped over on the sly
do you think people on here who have put a tech 2 body kit and a 325i lump or an m50 lump in to an old 316 shell call it a 316 ? , or matey whos building his m3 in the photogalley section in a 316 shell will call it a 316 when its finshed ....
go back further to mk 1 escorts or any other classic cars that have been built upon a shell
i certainly dont care and neither do i try to lie about it, the car and threads about it can even be seen on the s1 mk3 escort forum and passion ford, going back to when i 1st bought the shell and the project , search it out
stew72
Post Fri Apr 20, 2012 8:23 pm
there's no way I'd take on one of these if its available for less than 4k, and I have access to one of the largest privately owned stash of spares.
Post Fri Apr 20, 2012 8:35 pm
polsta wrote:very early xr3 were sunburst red, same as only a few were made with a 4 speed box ,then they went to injection engines and rosso red and looked exactly the same , same wheels,spoiler,kit
Here^^^
^^^^^It is wrong for an XR3, Rosso was not available till '85, way after XR3 production ended in '83 for third time!
polsta wrote:and i then put up pics of a mint low milage rosso red xr3 that looked exactly the same
NO you posted a pic of an XR3i, not an XR3.
polsta wrote:only difference is a non injection engine
There are many other differences between the XR3 and XR3i.
polsta wrote:its an xr3 re shell in a a latter color which is still exact same styling and looks, bar the injection engine
It's clearly not the same as its the wrong colour for an XR3 or the 100th time!!
polsta wrote:i call it an xr3 yes, you got a problem with that ?
polsta wrote:inve never pretended its something it isnt
Hmmm.
polsta wrote:do you think every owner whos ever re shelled an rs1600i in to a different chell would call it a 1.3 popular and not an rs, old ford re shells are a common thing and many many cars have been re shelled, the shells are the same anyway, how many mk1, 2,3 , escorts are out there that have also had the id and number plates swapped over on the sly
Yes, using a donor shell to reshell a rotten car is very common in Ford circles BUT is it technically ringing.
Have you swapped you chassis number an reg number over from your XR3 to the 1.3 Laser shell?
If so then you have a ringer, if not then you have a 1.3 Laser with some XR3 bits. End of.
polsta wrote:do you think people on here who have put a tech 2 body kit and a 325i lump or an m50 lump in to an old 316 shell call it a 316 ? , or matey whos building his m3 in the photogalley section in a 316 shell will call it a 316 when its finshed ....
See above! And anyone who says the 316 is anything other than that is talking shit!
If matey even begun to call is P40'd 316 an M3 he would be ridiculed for being so delusional!
polsta wrote:go back further to mk 1 escorts or any other classic cars that have been built upon a shell
Yep, plenty of ringers out there using old shells.
polsta wrote:i certainly dont care and neither do i try to lie about it
Stop calling it an XR3 then as it clearly isn't, never will be and isn't even that good a replica.
Post Fri Apr 20, 2012 8:53 pm
typical fwd scort zaust,speed hump scraper angle of dangle :mad:
Post Fri Apr 20, 2012 8:55 pm
Shouldn't be that low!
You can see the whole thing is on the p!ss as the tail pipe is near on touching the rear panel.
polsta
Post Fri Apr 20, 2012 8:58 pm
il call it what i want, its an xr3 re shell
a 1.3 laser... has different interior, different bumpers, different grill, chrome window strips on the front/rear glass, a different engine, different shocks, different springs, different exhaust, different steering wheel, different gear knob, different wheels
theres nothing 1.3 laser about the car now is there
ive not changed the ids, and its not a ringer, and its a different color car
the last part, its not a good replica .... feel free to point out all thats wrong with how it looks thats so bad then and point out for us all
and its not even the finished article any way and just a little project and i certainly wont loose any sleep over you trying to put it down coz your a bit of a saddo like that
Post Fri Apr 20, 2012 8:59 pm
i have some pics somewhere in an old school album of my rst mk111 van in gloss black on an 83 y plate converted to mk1v front end but that would be too council to post surely :D
Post Fri Apr 20, 2012 9:03 pm
Carl, what does it say on the log book?
It hasn't even got a black headlining and its still got chrome round the windows!
Call me what you like but you still have a Laser.
polsta
Post Fri Apr 20, 2012 9:04 pm
bss325i wrote:Shouldn't be that low!
is that it ? seriously, what you on about :roll:
how is this on the piss or too low ???
if that's his car it needs a drop badly 8O
i'd fit the zaust properly first though.
Post Fri Apr 20, 2012 9:06 pm
how is this on the pee pee or too low ???
Not your bloody laser you mong!
The bloody XR3i me and Magpie were talking about! :mad:
Keep up! :)
magpie wrote:typical fwd scort zaust,speed hump scraper angle of dangle :mad:
polsta
Post Fri Apr 20, 2012 9:08 pm
bss325i wrote:[]
your just cluthcing at straws now, feel free to point out the fact ive not mentioend the chrome and said thats one of the last jobs needed to be done
and why is it the wrong colour... that picture is a fail , it would be a fail the body kit and wheels etc were never put on a car that color, but they were, what the fook are you on about :roll:
Post Fri Apr 20, 2012 9:10 pm
is it x'ssed with a hi lux ?
Post Fri Apr 20, 2012 9:15 pm
polsta wrote:and why is it the wrong colour... that picture is a fail , it would be a fail the body kit and wheels etc were never put on a car that color, but they were, what the fook are you on about :roll:
BECAUSE YOU CANT GET AN XR3 IN ROSSO YOU RETARD! :mad:
You keep harping on about your Laser being an XR3 reshell, replica whatever but its in the wrong colour for an XR3.
FAIL!
It's like trying to make a tech 1 325i Sport replica in Zinober red.
Wrong colour!
Post Fri Apr 20, 2012 9:18 pm
gotta get the basics right 1st is what barry is saying,it just metal to me fwd fords.
polsta
your just getting yourself at it over the I, like i said , xr3/xr3i both look EXACTLY the same ,like i said bar the fooking injection engine and the decal on the back , go and have a cup of tea and stop getting yourself bang at it
Post Fri Apr 20, 2012 9:21 pm
aren't you all over a ford forum with this xr3 'jobbie'
it's real winkeye
Post Fri Apr 20, 2012 9:25 pm
polsta wrote:your just getting yourself at it over the I, like i said , xr3/xr3i both look EXACTLY the same ,like i said bar the fooking injection engine and the decal on the back , go and have a cup of tea and stop getting yourself bang at it
Yes they have the same wheels and spoilers and share some exterior colours but there are many more differences between XR3's and XR3i's, for the second time.
Rosso is wrong for an XR3.
End of!
Post Fri Apr 20, 2012 9:27 pm
XR3 my arse.
It's a Laser, a miser spec run out model which was basically a popular with some tinsel on.
Post Fri Apr 20, 2012 9:29 pm
didn't a laser have a 5-speed box ?
Dezzy
Post Fri Apr 20, 2012 9:36 pm
If you'd bought a rotten Tech 1 sport (oh yeh you did) but instead of having the shell welded you found a cracking chromie, good luck. Then set about swapping everything over. It would never be a sport would it?!
That's why your ford will never be an XR3. No matter how nice it is!
Post Fri Apr 20, 2012 9:38 pm
Dezzy wrote:If you'd bought a rotten Tech 1 sport (oh yeh you did) but instead of having the shell welded you found a cracking chromie, good luck. Then set about swapping everything over. It would never be a sport would it?!
Nail on head.
polsta
Post Fri Apr 20, 2012 9:39 pm
End of!
externaly- the xr3 and xr3i looked exactly the same , bar the xr3/xr3i badge on the back, mine is blank , like i said...so there for it doesnt LOOK the wrong color and nothign visualy wrong with it
the difference your on about, would be with the engine, rosso red cars had the injection engine, thats the differece your harping on about which is wrong as its got a carb engine with an injection colour
the car is the correct color for the year, correct wheels,spoiler,body kit, black tailgate and everythign else cosmeticly bar the chrome
Post Fri Apr 20, 2012 9:44 pm
polsta wrote:the car is the correct color for the year, correct wheels,spoiler,body kit, black tailgate and everythign else cosmeticly bar the chrome
Yes that's all correct for an XR3i BUT you call it an XR3, XR3's don't come in Rosso! :mad:
Wrong colour = FAIL!
and the log book.
Post Fri Apr 20, 2012 10:06 pm
Barstewards !!
got me scanning Ebay for Xr3i's, dunno why they were shit when i owned them 18 years ago :D
check out this badboy :wink:
http://www.ebay.co.uk/itm/1985-FORD-ESC ... 4602e41e42
Post Fri Apr 20, 2012 10:11 pm
That's nice Steve!
Here you go Carl, a real one AND in Rosso!
http://www.ebay.co.uk/itm/1985-FORD-ESC ... 736wt_1270
csl
Post Fri Apr 20, 2012 10:24 pm
e30topless wrote:Barstewards !!
That is fooking fantastic! 8)
Post Fri Apr 20, 2012 10:32 pm
Are they that bad then? I've been used to the foibles of using classic cars as daily drivers, so am fairly capable at most things. After all, that Lotus twin-cam is just a Ford crossflow underneath all the fancy gubbins on top, isn't it? :wink:
