Rolling Road Day Graphs
M5pilot
Mon Nov 26, 2007 7:26 pm
Hi All,
Rolling road day graphs:
Toby Unna
Steve Kelly (E28 535i)
RIC (E30 320iS ith Carbon Airbox / Alpha N)
Mark Wilson ( E30 318iS with Chip)
Malcolm Webster (E30 320i with 2.7)
Jamie Myles (E28 528i)
David Oakshott (E30 2.7)
Barry Sheward (e30 325i with 42k)
A Billingham (E28 535i)
Karan Punni (E30 with S38 3.6 M5 Engine)
Sal
SCOTT325SE
Mon Nov 26, 2007 8:20 pm
Sal, I assume that those are Flywheel(first) graphs and 'at the wheels' (second) graphs yes?
oakey
Mon Nov 26, 2007 8:29 pm
^yup.
Tanks Sal. :cool:
Have to do it again soon :D
MickyDojoh
Mon Nov 26, 2007 11:54 pm
Some nice figures there guys
**BANNED**
Tue Nov 27, 2007 10:57 am
A grand day out!!
Youth is wasted on the young.
d6dph
Tue Nov 27, 2007 11:07 am
Karan's car is a monster, That's some serious grunt in an E30!
Nice work Sal
ste
Tue Nov 27, 2007 11:40 am
Some cracking results there. 8)
e21Jason
Tue Nov 27, 2007 11:52 am
Hi Nice work
I done a quick table to compare engines and benchmark the outputs & trans losses
Jason
Engine BHP F BHP W Loss %Loss BHP/Litre
m30 turbo 295.6 243.6 52 17.6 84.5
m30 194 155.3 38.7 19.9 55.4
s14 2.0l 171.8 142 29.8 17.3 85.9
m42 129.4 105 24.4 18.9 71.9
m20 2.7 178.3 141.3 37 20.8 66.0
M30 2.8 184.8 146.9 37.9 20.5 66.0
m20 2.7 205.7 165.1 40.6 19.7 76.2
M20 2.5 172.7 136.4 36.3 21.0 69.1
M30 3.5 213.7 173 40.7 19.0 61.1
S38 3.6 296.7 244.3 52.4 17.7 82.4
**BANNED**
Tue Nov 27, 2007 12:41 pm
What makes the transmission losses vary?
ShepsEvo3
Master of go faster
Tue Nov 27, 2007 12:48 pm
daimlerman wrote:What makes the transmission losses vary?
Oooo... don't go there! :P
www.sabre-tuning.co.uk
**BANNED**
Tue Nov 27, 2007 1:01 pm
Hoped to start a debate,not a fight!! I was running ATF in the gearbox but only gained a mid position on losses.The lowest losses are against the highest powered cars...
ShepsEvo3
Master of go faster
Tue Nov 27, 2007 1:06 pm
daimlerman wrote:Hoped to start a debate,not a fight!!
Who's fighting? :? It was a light hearted comment :roll:
ChrisBarns
ConvertibleChris
Tue Nov 27, 2007 1:07 pm
daimlerman wrote:The lowest losses are against the highest powered cars...
I'm at work so haven't time to think about this properly but wouldn't that be what you'd expect as losses are expressed as a %. Standard gearbox has same friction in each car but with a more powerful engine loses will be a smaller percentage?
**BANNED**
Tue Nov 27, 2007 1:14 pm
Sounds logical.... :o:
e21Jason
Tue Nov 27, 2007 1:42 pm
Hi
If you look at the figure 19% is average with a range of 17 to 20% for the losses, and it tends to drop on bigger power cars.
Jason
Turbo-Brown
Boost Junkie
Tue Nov 27, 2007 1:45 pm
YIKES!
Does this wanna run slightly leaner?!!
Tue Nov 27, 2007 7:25 pm
Most pleased with my result and proof that a standard (has made 171bhp on 2 different dyno without the ITG) late low comp M20B25 can make 170bhp! :D
Tue Nov 27, 2007 8:45 pm
low Karan's torque curve! nice and flat!
Gunni
Tue Nov 27, 2007 9:49 pm
Turbo-Brown wrote:YIKES!
This is totally fine, as this is a high strung 2.0, so at WOT at low rpm it´s still not opening the afm at all, the load is minute to say the least.
I´m sure if the duty on the injectors would have been logged it would have shown how little air is going through, or the Voltage from the AFM.
With great challenges comes great engineering.
Gunni
@ 2012 VEMS group buy !!
Demlotcrew
Tue Nov 27, 2007 11:34 pm
^ Gunni it doesnt have a air flow meter!
Its mapped wrong at a guess.
Andrew
Gunni
Wed Nov 28, 2007 12:23 am
Demlotcrew wrote:^ Gunni it doesnt have a air flow meter!
Andrew
It doesn´t matter that much,
normal chips/tuning shows high 15-16´s at very low rpm and then gradually moves to 13.5-12.5ish depending on car at WOT.
You must understand that WOT on a 2.0car that is about 4k away from beeing on cam isn´t a dangerous thing.
This is where engine load and fuel requirement tuning understanding shows.
I would have tried 15s down to 12.5 after it got on cam.
Gunni
Demlotcrew
Wed Nov 28, 2007 12:33 am
Not a S14, on wot they show 12-14 all through the rev range.
This 320is is running very lean! I think it might need a few tweaks on the old MAXX
I would have liked a steady 12.3-13.5 as thats what S14s respond to best. (mines is 12.9 :D )
Andrew
reggid
Wed Nov 28, 2007 3:02 am
Andrew
while agree its not dangerous the torque curve shows issues below 3500rpm (unless it wasn't fully unleashed until 3500rpm).
The most impressive result is oakey's 2.7 the torque below 3.5k matches a 3.6L S38......a standard head and cam will do that and peter off quickly so don't over cam it oakey in the chase for topend.
Turbo-Brown
Boost Junkie
Wed Nov 28, 2007 7:42 am
18:1 though?!
It might not be consuming much air down there, but the air that is going in needs fuel going to match the throttle opening!
drifty325i
Wed Nov 28, 2007 8:02 am
Awesome thanks for posting! whats Karens car run in the 1/4? Thats almost what mine will push at the wheels 8)
Gunni
Wed Nov 28, 2007 11:21 am
Turbo-Brown wrote:18:1 though?!
Why?
The air amount and fuel are so low at a relatively low air temp that when compressed it CAN´T detonate without stupid timing it can´t ping either.
worst comes to worst he´d get a miss fire.
Air flow / Engine size = Load.
When you have a VIPER engine gulping in as much air as this S14B20 can do at max rpm and WOT, the viper engine does not need 12.5:1 afr. As the airflow is relative to engine size.
Throttle POS and manifold pressure isn´t really the actual load points.
Air flow always is though,
That´s why you almost always need a complete remap if you change a cam, intake or exhaust in a MAP/TPS system.
But with a MAF system, you would just have to adjust the now higher optainable flow rates.
As 100kg/min (let´s say 2v on he MAF) will always be the same load to the same engine as it´s size hasn´t changed
Now if you change the engine(cam for instance) the 100kg/min maybe gotten at a lower throttle pos so you still want the same amount of fuel in,
the ecu still looks up 100kg/min at the same rpm and gives the required fuel, same with timing
This is the reason OEM is most often or not always now MAF based.
But I will agree that I would have tuned it richer. basically at the leanest point possible on a dyno without loosing power.
Gunni
ShepsEvo3
Master of go faster
Wed Nov 28, 2007 12:52 pm
Agree'd. way too lean for WOT, is definately loosing power there with 18:1, should be more like 14.7:1 or less at those RPM's and certainly by 3000 I would say 13.5/13.2:1 for optimum power. All S14's I've mapped so far have "liked" these AFR's, no less on WOT.
Wed Nov 28, 2007 7:16 pm
What is WOT?
exup
Boost Junkie
Wed Nov 28, 2007 7:22 pm
wide open throttle
Wed Nov 28, 2007 7:33 pm
Thanks. :)
oakey
Sat Dec 01, 2007 1:45 pm
reggid wrote: The most impressive result is oakey's 2.7 the torque below 3.5k matches a 3.6L S38......a standard head and cam will do that and peter off quickly so don't over cam it oakey in the chase for topend.
:D Could you explain to me (in idiots terms :D ) how the characteristics of my engine will change and why with a cam please? ( I've never had it explained to me properly before)
