does it make any difference in the width you can go to by using 15 , 16, or 17inch rims
thanks spook
It's not just the width and drop you have to consider the offset too. If you had a higher offset, providing you've got inner arch/damper clearance you'd gain clearance at the arch and you'd probably be fine.D1MYY wrote:Also depends on the drop.
My 16X9j rub on the back with rolled arches and 60 or 80mm drop. Fronts no probs with 16X7.5J
Aren't most 9j wheels that fit an e30 et15?ste wrote:It's not just the width and drop you have to consider the offset too. If you had a higher offset, providing you've got inner arch/damper clearance you'd gain clearance at the arch and you'd probably be fine.D1MYY wrote:Also depends on the drop.
