Hi,
I drive my e30 to work (17 miles) and back every day and often more. The temperature gage gets to a quarter and stays around there even if I am driving fast reving highly for 3 miles or so it stays the same. Is that normal? It has once nearly reached the middle when sat in traffic for 30 mins or so. It seems ok but seems odd??
cheers, Leyton
Engine temperature??? 1986 325i soft top
Why does it seem odd ?
It is perfectly normal behaviour. When you drive normally the air flow over the radiator is enough to cool the engine. When you sit in traffic, with no air flow, then once the temp gets a bit higher the fan kicks in - forcing air over the radiator.
G
G
I deserve 6 of the best ...
- Brianmoooore
Exactly as it should do. Why do you think it's odd?
Wish mine did that.... seems to sit at half way on gauge (in traffic) and it went to 3/4 once, but I know I have a fan coupling to change!
E34 525tds - on the way to replace 325i
E30 / 34 spares
E30 / 34 spares
- Brianmoooore
the E30 is a bit more sophisticated than 'modern' (non BMW) cars.theflop wrote:Just that more modern cars I have owned in the past would sit right in the middle even whendriving normal.
The whole non-coloured centre section of the gauge only covers a few degrees from side to side.
You wouldn't even notice the difference in needle position on another car with this difference in temperature.
- Frog freak !
Perfectamondo dude
