E30Mark wrote:There isn't a OBC module box behind the glove box
Possibly is on a left hooker! Unless the OBC loom is reversed on these?
In answer to the OP's question: The OBC can effect the cars running, as Taz says. The ignition switched supply to the ignition coil and ECU passes through a relay controlled by the CODE function of the OBC.
It's highly unlikely that a six button OBC with the problems described above is causing any running problems, but if this relay was faulty, then it could.
Wire a small 12V bulb or LED between the + terminal of the ignition coil and earth, and position it somewhere so that you can see it when driving.
Should remain steadily lit all the time the engine is running and ignition on, with just some dimming when cranking.
