Cool - so can it be polished? Would you end up with a white edge?Nadeem wrote:camshaft...it did come in a body wrap which is how I fitted the first part on the bonnet...but when it came to the side...the body wrap doesn't handle the curves too wellso in order to avoid loads of air bubbles and constant re-arranging...it was easier to remove the individual squares from the body wrap and stick them on one by one(hence my little mistake towards the front
)...once you've done the bonnet, you've gained some experience in doing them and you also now have a guide to follow for the side...hope that makes sense
