now we all like a bit of rwd action...but does anyone have some more info on the 4wd system bmw fitted to some e30's and e34's?
is it permanant 4wd or is it/can it be adapted to a switchable setup?
is it reliable?
what sort of system is it?(vauxhall 4wd viscous coupling requires all tyres to have the same tread always...paaain)
apart from clutch and other 'non related' mods, what sort of power can you run through the 4wd without things breaking?
guessing you still use a normal rear diff hence lsd....can one (lsd)be fitted to the front?
im ignorant as you like on this subject soo im probs miles off....correct me at will
