Hmm, almost negative feedback on a wild chip, new one on me
I have had two occasions where the new chip did not alter any settings within the ECU, this I can only assume was caused by the ECU itself having a permemnt "memory" of the original map , and as such even though new sooftware was added ( chip) the ECU would not " look " at that data and carry that accross into volatile memory, swopping ECU for another with the same chip did alter the characteristics, 380's are worse for some reason.
anyone with a chip issue should contact me directly, contact detail are sent with every one( yep, that slip you all binned
HTH
Email FTW
