Z3 Rack Swap
Hello all!
I’ve managed to find a Z3 2.7 Turn rack (3213 1094038)
As per the wiki ‘ The fastest rack, and no need for a custom steering linkage, makes this the perfect rack.’
Is it really that easy to fit this rack? Can I still use E30 power steering lines or do I need custom ones?
BristolE30
I’ve heard this too!BristolE30 wrote: ↑Tue Apr 21, 2020 9:57 amI’ve heard that for RHD it is for the linkage? Not 100% sure though
i think the length is still wrong, i use first used the E36/E30 hybrid with my Z3 rack but it shagged out in a few years, but now have the DanThe solid one spline shaft that uses E34 UJ or something IIRC which is what i recommend . Contact DanThe
E30 325is with M20B31
BristolE30
Hi Dan,
In your opinion which is the easiest rack swap? The E46 one?
BMW E30 316 ‘87
BMW E30 325i ‘88
Bristol, UK
BMW E30 325i ‘88
Bristol, UK
BristolE30
bear in mind that there is a difference between the racks so the E36 rack might fit some exhasust manifolds but not others. case in point is the Z3 rack does not clear the BTB3 manifold. the BTB3 was made for the E36 racks but there is interfence with the Z3. ask me how i know
Ouch...reggid wrote: ↑Sat Apr 25, 2020 3:16 ambear in mind that there is a difference between the racks so the E36 rack might fit some exhasust manifolds but not others. case in point is the Z3 rack does not clear the BTB3 manifold. the BTB3 was made for the E36 racks but there is interfence with the Z3. ask me how i know
yeah was not a happy camper, fortunately it was relatively close and was able to get it to workJungleGus wrote: ↑Sun Apr 26, 2020 12:16 pmOuch...reggid wrote: ↑Sat Apr 25, 2020 3:16 ambear in mind that there is a difference between the racks so the E36 rack might fit some exhasust manifolds but not others. case in point is the Z3 rack does not clear the BTB3 manifold. the BTB3 was made for the E36 racks but there is interfence with the Z3. ask me how i know
- Contact:
The fabled 2.7 turn Z3 unit usually has a steel body and as such is a different physical shape, ive never looked close enough to see if anything other than the main hydraulic connections/mountings are different though
BristolE30
I have a Z3 rack in mij (LHD) 318iS and got it too fit with the (shorter) linkage that was allready in my (powersteering) car...
I do however have the issue that the stock E30 pressure lines will not, ever (no mather how many times and how carreful i try with new crusher washers) work without leaking.
+ I have a weird "scraping/rubbing" sound when i turn my wheel..
Do i need custom pressrure lines, or will the E36 line work?
Do i need to adapt the firewall? To get rid of the noise..
Hoping DanThe will jump in here
Dan`s your man mate !!!!MrriS wrote: ↑Fri Oct 15, 2021 5:54 pmI have a Z3 rack in mij (LHD) 318iS and got it too fit with the (shorter) linkage that was allready in my (powersteering) car...
Hoping DanThe will jump in here![]()
Hmh.. anybody else got some advice? Seems like Dan is a bit busy.. which i full understand, but i would really love to find a solutionMrriS wrote: ↑Fri Oct 15, 2021 5:54 pmI have a Z3 rack in mij (LHD) 318iS and got it too fit with the (shorter) linkage that was allready in my (powersteering) car...
rix313
- Contact:
Incorrect on the linkage. It is a standard PAS E30 linkage.
You 'can' bend the standard lines, but I spent a couple of hours on it and it was hard work, looked crap and I wished I didn't bother. Best thing to do is buy a pipe kit from BM Conversions, save the hassle and have new lines.
Too bad they aren't available in LHD / Europerix313 wrote: ↑Sat Oct 23, 2021 11:58 amIncorrect on the linkage. It is a standard PAS E30 linkage.
- Contact:
I do a kit for S14 LHD but am yet to make lines for other engines, there is hardly any demand for them here, I can of course make up new lines on your car in my workshop
As for the linkages, depending on which rack and the position in the subframe you mount it in, the standard linkage may well fit with no engine in the bay, but if it gives enough clearance to an exhaust manifold is a differnt story, as a general rule the linkage will need shortening, see link -
MrriS wrote: ↑Fri Oct 15, 2021 5:54 pmI have a Z3 2.7 rack in mij (LHD) 318iS and got it too fit with the (shorter) linkage that was allready in my (powersteering) car...
Since the project "fell on the back burner" this still isn't sorted.. Is there any further development in the hoses department?
I'll get them to you next week! I presume it will fit just fine as the S50 is quit a bigger lump than the mighty litlle M42
