Odd speaker issue, bad head unit??
JackLeach1
Fri Sep 10, 2021 9:48 am
On my 1991 318is with the stock radio, only the back left speaker worked. I bought four new jbl 521f to install, as my car doesn’t have premium sound. Even after replacing all 4 speakers, the speaker locations that didn’t work before still don’t work. All the speaker connections are in good order, and all the associated fuses are good.https://snaptube.cam/
Am I correct to assume this is an issue with the connection at the head unit or an issue with the head unit? I plan on pulling the head unit tomorrow to check. Thanks!
Fri Sep 10, 2021 3:06 pm
Welcome to the zone mate and it "sounds" like you have hit the nail on the head !!
Pics of your car might confirm this lol winkeye winkeye
Blanca
Sat Sep 11, 2021 11:52 am
Confirm by selecting the output wire for the good speaker and linking it to the other three one at a time , if the other 3 working well as the good one then it is the head unit, the head unit is OK with powering two speakers at the same time without damage.
But it does sound like the power output ICs have gone on three.
All comments by me should be taken in the right sprite, Jack Daniels is fine.
