I don't think I need to get the head skimmed as it never actually overheated, just used to lose water and misfire on startup - assuming water was leaking into the furthest back cylinder overnight and making the plug damp.
also discovered some perished hoses, gaskets and fuel lines along the way so will replace those on the rebuild.
How would you guys recommend cleaning the surface to put the gasket on when I go to put it back together?
