Need help to identify a engine 2.5 or 2.7 :-/
MOODY
Sun Feb 09, 2014 6:00 pm
Need some help lads to identify this mysterious engine.
Right the head has the following numbers
1705885 2.5/2.7
The bottom end has the following numbers
28c89
1289575
25 6k 1
23016837
sweep
Sun Feb 09, 2014 6:01 pm
2.5
MOODY
Sun Feb 09, 2014 6:07 pm
What cars it out of ? Year etc as I've tried to connect a late loom to injectors and it's not the same. A spec on engine would be good :-)
Sun Feb 09, 2014 7:20 pm
Its a low comp 8.8:1 cat prepped M20B25 engine from a post '88 car.
Grrrmachine
E30 Zone Wiki / Team Member
Sun Feb 09, 2014 8:07 pm
As others have decoded, the key part is the "25 6k 1" part.
This means 2.5 litre, 6-cylinder, designed for Katalyser (meaning low-compression).
The number that follows that is the build number for that engine.
MOODY
Sun Feb 09, 2014 9:05 pm
bss325i wrote:Its a low comp 8.8:1 cat prepped M20B25 engine from a post '88 car.
Thank you for the info
MOODY
Sun Feb 09, 2014 9:06 pm
Just need to find out which ecu to use and wiring loom
Sun Feb 09, 2014 9:10 pm
Late M20 loom should fit.
The 2.7 stamp appeared on the head casting, along with 2.5 after the introduction of the US Super eta E30.
MOODY
Mon Feb 10, 2014 4:01 am
Does not fit the injectors
Mon Feb 10, 2014 9:42 am
In what way? Spacing? Design of plug?
MOODY
Mon Feb 10, 2014 10:00 am
Design the engine had a part loom on it but cut, the injectors ain't straight plus it was a wire loom that was on then unlike the later loom which has the caseing on it
