Waterjet Cutting Company
Phill172
Thu Dec 19, 2013 9:15 am
Got a couple of bits for the e30s that I need profiling by a waterjet.
Unfortunately the only companies local to me want batches 10000's, so I was wondering if anybody has had any experience or can recommend me a company to do the work?
ross2009
Thu Dec 19, 2013 8:03 pm
i know people with a company near me will do one offs for some beer money
Turbo M20
v8 project 6.0 twin turbo
Phill172
Thu Dec 19, 2013 11:33 pm
Ah ok, if you could let me know that would b great!
Thanks!!!
kam-325i
Fri Dec 20, 2013 12:24 am
Has it got to be water cut ?
suedenim
Fri Dec 20, 2013 2:04 am
I don't understand why you would have to order more than one, it's just a case of adding your cad drawing to a space on the sheet, takes no time :mad:
1982 E21 316 Baltic Blau
1989 318i 2 Door Sterling Silber
Feedback: http://www.e30zone.net/modules.php?name ... highlight=
Phill172
Fri Dec 20, 2013 10:02 am
Preferably water cut, however it is only mild steel at 20mm, so laser cut isn't to much of an issue
Davebmx
Fri Dec 20, 2013 11:03 am
Theres also edm wire erosion where I work www.Amdale.co.uk
capnmchl
Fri Dec 20, 2013 11:31 am
Surely you'd be there for years trying to EDM 20mm steel?
Phill172
Fri Dec 20, 2013 11:59 am
Edm?
Have never heard of that!
I have lots of components that I require doing, the reason for short batch runs is for testing to start with, but even so im still only ever going to require that amount that are ordered.
Frustrating as google search only brings up the biggest companys around
beemerbird
Fri Dec 20, 2013 12:12 pm
http://www.candwseals.co.uk/waterjet_cutting.html ?
I googled 'small run waterjet profiling uk' and got a number of results :)
capnmchl
Fri Dec 20, 2013 2:07 pm
Phill172 wrote:Edm?
Electrical discharge machining. It basically erodes the material away through sparking.
I would imagine that laser or abrasive water jet is your best option for 20mm thick steel, but at that thickness you may start to have issues with tapering and poor finish on the exit side.
My friends dad is a blacksmith and gets stuff laser cut by a company in wiltshire. I had some carb adaptor plates done last year in 10 and 5mm mild steel. I'll see if I can find out who the company is.
capnmchl
Fri Dec 20, 2013 2:32 pm
http://www.hjknee.co.uk/KAM/
KAM engineering in Trowbridge. Will do laser cutting up to 15mm and water jet up to 100mm
Phill172
Fri Dec 20, 2013 3:15 pm
Thanks very much, yes it's why I preferred water as it gives a cleaner cut and finer tolerances
Sad thing about British industry is I can get it machined in Poland for half the price but unable to monitor the wuality
capnmchl
Fri Dec 20, 2013 4:21 pm
When going British, I've discovered the eccentric man in a shed who has an outhouse for a toilet does the best and cheapest job.
(And I do know an eccentric man who works in what could be described as a shack, with an outhouse, who does good, cheap machine work. He drives a 190E though.)
