any one fited a Check Control Panel to a soft top ??
or is there a how to guide ?
Check Control Panel
The full wiring diagram is in the bentley bmw manual, i have retro fitted this to a 316 years ago, make sure you have a full kit to start with (ie the resistor pack for the front head lights, and if your fitting it to a 318 you will have to modify your sump to fit the oil level sensor). On a scale of 0-10 level of difficulty i would say its a 4 to install, as long as you are competent with wiring if not your car could go up!
Jesus325iTouring
- Frog freak !
Too a what, and dang you must be oldajay wrote: i have retro fitted this to a 316 years ago
