Advice on spark plugs please!
ultimatime30
Thu Apr 25, 2013 11:10 am
Anyone have a preference as the best ones to have?
HJG-E30
Thu Apr 25, 2013 11:14 am
I've always found single electrode standard NGK to work best
Mo13
Thu Apr 25, 2013 11:37 am
as above NGK
ultimatime30
Thu Apr 25, 2013 12:05 pm
Are they the copper core ones?
Thu Apr 25, 2013 12:07 pm
NGK BPR6ES are recommended as being the best for the M20 engine.
jmc330i
Thu Apr 25, 2013 12:30 pm
Stay away from the multi electrode plugs. I can remember a thread on a Vaux forum about an XE lump that had one of the electrodes bouncing round inside the cylinder, but because there was another electrode making a spark and there was no misfire, the guy didn't realise anything was wrong until the damage was done.
Possibly not a common problem, but something I'd steer clear of anyway.
James
'91 325i Sport
'93 318i touring 16v
Thu Apr 25, 2013 1:39 pm
Speedtouch wrote:NGK BPR6ES are recommended as being the best for the M20 engine.
This.
Has been proven on the rollers more than once that they run better with an NGK than other plugs.
Quaser
Thu Apr 25, 2013 1:58 pm
what about m50/m52 engines
maybe we should have a wiki on recommended spark plugs for all engine variations
ultimatime30
Thu Apr 25, 2013 2:51 pm
Can't believe how cheap them NGK plugs are! 8O
Morat
Thu Apr 25, 2013 3:06 pm
But good quality. Hard to believe eh? :)
ultimatime30
Thu Apr 25, 2013 3:15 pm
Absolutely! Almost wish I had a V8 in it now hehe
ultimatime30
Thu Apr 25, 2013 4:41 pm
Thanks for your replies guys, appreciate it :)
faze30
Thu Apr 25, 2013 5:23 pm
NGK ARE THE ONES DUDE
zaust
Zone day release
Fri Apr 26, 2013 12:38 am
Early high comp m20' s and m10's need Bosch and all later engines ngk.
M30 Tech 1 Touring on gas.
reggid
Fri Apr 26, 2013 3:47 am
This.
if only the rollers were that repeatable...., a properly calibrated and monitored engine dyno could pick up something perhaps. id like to see something conclusive new plug stock vs new plug BPR6ES (one heat range cooler)
in reality there is not going to be any decernable difference between the stock and BPR6ES unless you have a much higher comp lump and if it is not a higher comp lump you could get too many deposits which could be a minor issue long term. ive run BPR6ES and bosch stock ones and ZR5xxx and even BPR5ES it is much of a muchness TBH. ive dyno tested fancy CDI coils systems and they do SFA on a naturally aspirated engine with minor redlimit increase
E30 325is with M20B31
