M3 Wheel fitment? (Wheels on - with Pics ;-) )
virdi325i
Sun Jan 13, 2013 12:51 am
Hi
Quick question, will the below fit an M3. Thinking of buying a second set of wheels
front 8.5 x 17" OFFSET - E14
Back 10 x 17" OFFSET - E28
snakebrain
Sun Jan 13, 2013 1:11 am
ET is 20 or thereabouts for an M3, I think..
harry_p
Sun Jan 13, 2013 1:31 am
They should be ok, but you might need to be carefull with your tyre choice, and you won't know if they'll clear the front brakes until you try them on. The calliper sits quite forward in the wheel on m3s.
Rears might need a small spacer.
cheers,
harry
Kos
Sun Jan 13, 2013 2:02 am
I've run 8.5 x 17 et13 & 10 x 17 et20 on my m3
One set was borert C's and they cleared the brakes with lots space
My MK morltorsports are the same size & et and also clear
However depending how low the car is, 10j on the back with 245 35's needed arch rolling
235 40's may have cleared but it's a stretch
Personally I think 8's & 9's with with 215/40 and 235/40 is perfect
www.pukardesigns.com
IG Pukar.Designs
Sun Jan 13, 2013 9:17 am
Sounds council ! :eek:
virdi325i
Sun Jan 13, 2013 10:36 pm
ok thanks, think i'll go for them. cheers
virdi325i
Mon Jan 21, 2013 7:53 pm
Hi
Ok so i got the wheels, only tried on the back wheel today..... It didn't fit :( it's scraping the spring mount on the inside, I'm gona try a 10mm spacer tomorrow to see if the clears it. currently its ET28 so will make it ET18.
By doing this I’m worried its going to bring out the wheel, so start scrapping the arch (they are rolled in, so hopefully not).
Has anyone else had this prob, is anyone got 10 x 17" OFFSET - E28 ???
I found this online, it's been very helpful.
http://www.rimsntires.com/specs.jsp
thanks
virdi325i
Tue Feb 05, 2013 3:22 pm
Hi All,
So i finally got around getting the wheels on and they fit without srubbing ;-)
I had to put 6mm spacers at the front (to clear the calipers) and 8mm spacers at the rear.
these are Alpina rims of a b12
anyway check them out
lyricalnut02
Tue Feb 05, 2013 3:43 pm
325i Sport Tech 1 - R.I.P
E30 addict.
Demlotcrew
Tue Feb 05, 2013 3:53 pm
Those dont look too bad at all :cool:
Tue Feb 05, 2013 4:02 pm
Suit the car very nicely :D
Tue Feb 05, 2013 4:14 pm
Sweet looking, but how do they ride at speed - any vibrations going on?
M3Jim
Tue Feb 05, 2013 5:10 pm
They look really nice, I've been thinking of picking a set of pinas up just for a change. Looks like quite a stretch on the front though! What tyres you running?
virdi325i
Tue Feb 05, 2013 5:19 pm
going to take on a long drive tomorrow and see how it goes, local driving today was fine, steering cuts without problems and goes over speed bumps fine.
Kos
Tue Feb 05, 2013 5:21 pm
That does look :cool:
IG Pukar.Designs
virdi325i
Tue Feb 05, 2013 5:23 pm
At the front i've got 215-40-17 and at the rear 245-35-17
I did it for the same reason, needed a change from the BBS Style 5's
THE_GODFATHER
Tue Feb 05, 2013 5:24 pm
Stunning :)
harry_p
Tue Feb 05, 2013 6:02 pm
Glad you got them on ok, and glad my advice wasn't a million miles out :D
cheers,
harry
Rosc0PColtrane
Tue Feb 05, 2013 6:37 pm
Very cool!
Low_E30
Tue Feb 05, 2013 7:08 pm
They look really good...
Location?...Beck theatre perhaps? :D
virdi325i
Tue Feb 05, 2013 7:57 pm
Thanks folks for all your advice regarding wheels ...... So glad they fitted.
Yes it's beck theatre...... Nice and quiet during the day :D
M3Jim
Tue Feb 05, 2013 8:16 pm
virdi325i wrote:At the front i've got 215-40-17 and at the rear 245-35-17
:) gimme a shout when you get bored of these! I think I'm gonna paint mine Nogaro for a change (it will be cheaper).
S14M3
Wed Feb 06, 2013 6:49 am
You've convinced me, picking up a set for the M as well!!
sunnyr83
Sun Feb 10, 2013 6:09 pm
Phill172
Mon Feb 11, 2013 10:41 am
Never been a fan of Alpinas, but wow they look amazing. It has really changed my mind! (and its red! :D)
