starting
spiderman
Fri Jan 25, 2013 10:42 pm
i have a flat battery, and i jump started the car, and it ran ok. then it died and i tried to start it again, still attached to my other car, via jump leads and it was totally dead. i have checked all the fuses and nothing appears to be blown, but still, there is no life in it. is there anything else that i could have fried.
Fri Jan 25, 2013 10:59 pm
Once again, what car???? We are not psychic.
spiderman
Sun Jan 27, 2013 11:30 am
what a idiot, sorry guys, it helps if i pay attention when asking questions. the car i have is a e reg 320i e30 4 door. sorry again any help appreciated.
Grrrmachine
E30 Zone Wiki / Team Member
Sun Jan 27, 2013 11:41 am
When it was running the first time, did the battery light go out? When it's connected to the other car, do you get dash lights when you turn the key?
It can be something as silly as a loose battery terminal, especially if you're using jump leads.
spiderman
Sun Jan 27, 2013 11:49 am
yes the battery light went out, at the moment i have no dash lights at all, i have put a new battery on it and there is still no life at all.
Sun Jan 27, 2013 12:23 pm
Check engine to body earth strap, and for any fusible links in the main battery lead to the ECU - they are small flat sections hidden under the wire sheathing.
spiderman
Sun Jan 27, 2013 2:23 pm
found the problem, i had pulled out a relay on the steering column, and had not put it back in, but once plugged back in away she went. i'm not very good at all this tinkering. thanks for ant advice given.
Sun Jan 27, 2013 9:02 pm
Speedtouch wrote:Check engine to body earth strap, and for any fusible links in the main battery lead to the ECU - they are small flat sections hidden under the wire sheathing.
That's why I asked "what car". Only the 325 saloon has any fusible link, so not relevant to a 320.
Sun Jan 27, 2013 9:05 pm
spiderman wrote:found the problem, i had pulled out a relay on the steering column, and had not put it back in, but once plugged back in away she went. i'm not very good at all this tinkering. thanks for ant advice given.
???????? Only 'relay' on the steering column is the unit that flashes the indicators. I've never known one of these to have anything to do with a car running yet!
There's a plug and socket clipped to the steering column half way down which can cause problems if not fully pushed together.
