rear camber
HairyScreech
More info needed, a standard uncrashed car shouldn't have geometry issues.
HairyScreech
HairyScreech wrote:More info needed, a standard uncrashed car shouldn't have geometry issues.
jaistanley
I made a rear beam that is adjustable. Screwed up my measurements whilst welding and now have only 0.75 degrees of camber.
Tyre wear and straight line grip is excellent but it handles like a slag in the wet!
You are looking for 1.5 degrees whilst at resting height on a level surface if I recall correctly (from the BMW geometry specs).
Jai
Jai
I have mine set wrong at the moment, next to no camber. I'm with you on the wet handling, downright terrifying sometimes lol!jaistanley wrote:I made a rear beam that is adjustable. Screwed up my measurements whilst welding and now have only 0.75 degrees of camber.
Jai
It on the list to be done, if this rain keeps up it'll be sooner rather than later.
'94 e36 tree climber
