So I put my 318iS into the mechanic to check a few things out yesterday, an oil leak and a strange noise from the o/s rear wheel.
The strange noise is a string in the brake pad area, simple enough fix and the whole lot will be replaced both sides.
The oil leak has turned out to be the bad news...the head gasket has gone
Also turns out that the rear bushes need replacing. Now has anyone upgraded to Powerflex bushes? Any opinions? I was considering this at some stage anyway, so now's as good a time as any I guess.
Also the o/s steering boot needs replacing, another simple fix.
Bit gutted really on the head, but there we go...good jobs it's a minter!!!
So advice on the rear bushes would be appreciated. Along with any sympathy, ha!
Jamie
