Rear screen
- **BANNED**
Rear 'screens are not the sort of thing that gets damaged or broken so should be readily available s/h.
Try a 'wanted' add in the correct section.
Youth is wasted on the young.
- **BANNED**
That should not be a problem for most of the zone's 'frequent fraggers' or 'approved traders'!NIX wrote:Thanks, but going to need someone to fit it too...
May be a little more difficult if you cannot travel far from North London,though!
I've got an untinted one with working heating element and the connection tabs intact- you can have it for £10 but you'd need to collect it from me ( 20 miles north of Birmingham )
mines a spare that i forgot to check before i fragged an old turd and if it works i'm using it.capri_rob wrote:It worked last time I used it
the rear demist has never worked on my car since i've owned it but that could be a fault somewhere else in the car maybe ??
+ a yard full of scrap turds
beemerbird
Do you still have the tags in your possession? I successfully attached tags from one (unfitted) screen onto the one that was fitted to my car. Or someone may have a broken rear screen that they can prise the tags off for you . . . . . . I'll find a link to the stuff I used to do this.
beemerbird
Hi beemerbird, that MIGHT work...Basically the connectors that attach onto the rear screen look as thought they've been snapped off - maybe the rear screen was replaced in the past and these bits not fixed back properly, not sure.
Perhaps I'll try to take a pic at some point to show what I mean.
beemerbird
That's exactly what had been done to mine, hence my use of the glue. I bought a second hand screen for a tenner, heated the intact tags with a soldering iron until they floated off. Then fitted the tags to my installed screen. Far less hassle IMHO.NIX wrote: the connectors that attach onto the rear screen look as thought they've been snapped off - maybe the rear screen was replaced in the past and these bits not fixed back properly, not sure.
