Under bonnet sound deadening.
kitch
Sun Apr 03, 2011 9:06 pm
Has anybody removed theirs and bought new from BMW? I'm thinking about this and was wondering if it's nla? If not how much? Also, the best way to remove all the old crap? I know I could ask BMW if it's available but they aren't open at 9 oclock on a sunday and I'm impatient.
Sun Apr 03, 2011 9:10 pm
it's readily available from the dealers and around £40 :D
kitch
Sun Apr 03, 2011 9:12 pm
Bargain, I was thinking it would be way more than that if they had it. Thank you!
RustyRuss
Sun Apr 03, 2011 9:48 pm
Bargain indeedy, im needing to do this as well :-)
Russell A Macfarlane
Central Scotland
Game
Sun Apr 03, 2011 9:56 pm
Use a nice sharp scraper and should come off nice and easy.
A sphincter says what?
RustyRuss
Game wrote:Use a nice sharp scraper and should come off nice and easy.
Excellent!! Cheers mate.
Central Scotland
Jim320i
E30 Zone News / COTM Team
Sun Apr 03, 2011 9:58 pm
I soaked mine in white spirits too to remove the old... Still havent got round to replacing it new though.
RustyRuss
Sun Apr 03, 2011 10:02 pm
Did it before with a few other cars of mine but where it has been one entire section and was a pita due to the size...hopefully this will be slightly easier due to the three smaller sectional aspect....in theory!!!
Central Scotland
Cloud
Mmmmmm Donuts!
Sun Apr 03, 2011 10:23 pm
I got a brand new one for mine, and it was chewed to f**k by mice in about 3 days. About £50 iirc but there's cheaper out there. I just scraped the worst of the old stuff away with a broken bit of number plate.
Sun Apr 03, 2011 10:26 pm
Dont use anything sharp unless you want to scratch the paint off, the best tool for this is a plastic filler spreader.
Anything with a blade or made from metal is just going to cause damage
Sun Apr 03, 2011 10:34 pm
From my sports thread.
http://www.e30zone.net/modules.php?name ... &start=675
bss325i wrote:Another job i have tackled recently is the under bonnet foam which is a common E30 problem and can be very unsightly under the bonnet when its old and crumbly!
A top tip for this job!
I have heard of other people tackeling this and it being very messy and time consuming. Well i have found something that speeds things up and reduces the mess!
Toytas own brand brake cleaner! It is solvent based and after removing the bonet, pulling of the bigger chunks of foam you are left with the glue still on the bonnet with a thin layer of foam.
The Toyota brake cleaner disolves the glue and foam and turns it into a mush that can be scraped of, near enough wiped off with plastic filler spreader and a rag.
Once the mush is removed a wipe down with the brake cleaner and the surface is ready to stick the new foams on. The brake cleaner does not damage the paint in any way either.
Much better! :D
Dezzy
CR24v it's a lifestyle
Sun Apr 03, 2011 10:41 pm
I missed that on your sport thread Baz.
I like it though. Does it have to be the rice brake cleaner only?
Sun Apr 03, 2011 10:43 pm
Celly thinners works fine
Sun Apr 03, 2011 10:48 pm
i thought it was more like £25?
Sun Apr 03, 2011 10:50 pm
DanThe wrote:Celly thinners works fine
it does, and it's definatly worth removing the bonnet to do this !
nickso
Sun Apr 03, 2011 10:53 pm
i agree with that, i started doing mine on the car and quickly removed it.
'88 e30 328i M52 track bint.
Dezzy wrote:I missed that on your sport thread Baz.
Anything that wont damage the paint but will eat the glue.
Sun Apr 03, 2011 11:19 pm
so any brake cleaner really then
Sun Apr 03, 2011 11:21 pm
Simon13 wrote:so any brake cleaner really then
No because some brake cleaners are water based and are shit.
Believe me i tried a few!
Sun Apr 03, 2011 11:23 pm
really i'd of never have guessed!
Sun Apr 03, 2011 11:26 pm
Dont be a dick! I found something that works really well and i thought i'd share.
Next time i wont bother!
Sun Apr 03, 2011 11:27 pm
ok. :o don't get sweaty
DaveD
E30Zone Wiki Specialist
Mon Apr 04, 2011 9:34 am
just a point of interest ...brake cleaner is very useful stuff ...its usually carbon ...fluoride and is great for getting all sorts of stains off clothes ...it is or is closely related to ..dry cleaning fluid :D
Gert_8
Mon Apr 04, 2011 12:53 pm
Guys; What is used to apply the new stuff, or is it supplied with a sticky back so that it's just pressed in place?
gooner1
Out humping Reindeer
Mon Apr 04, 2011 2:28 pm
Comes with a sticky back, just have to peel off the protective cover and voila!!
Jim320i
Mon Apr 04, 2011 2:51 pm
Being inspired by Barry's lovely pictures, I thought I would get down and get mine ordered from Sytner Leicester... Costing 38 and so many pennies... Will be there on wednesday :cool:
Also got a new rubber boot and breather hose as both of mine are in a bad way, so should be running that little bit better when fitted.
MJJ_ZX6RR
Mon Apr 04, 2011 2:59 pm
[slight hijack] Anyone able to comment on how much noise is surpressed by this sound deadening foam?
Reason being my M30'd cab sounds like the typical skeleton in a filing cabinet, and I am wondering if re-fitting new underbonnet sound insulation would help. I removed the original insulation years ago.
Martin
[/slight hijack]
Lots of bikes, the odd modern BMW, and now an 88 e30 335i Cab project with E32 running gear
Low_E30
Mon Apr 04, 2011 3:02 pm
Does it come as a kit consisting of the 3 pieces?.... Or can one buy individual pieces?
Two of mine are mint , i mean really mint... while the third one someone has pulled a chunk away at the corner....
E30 BMW 325i Cabriolet M-tech1 + Hardtop
W201 Mercedes 190E 2.5-16
W124 Mercedes E220 AMG Cabriolet + Hardtop
S124 Mercedes Estate AMG
C126 Mercedes 500 SEC
W210 Mercedes E55 AMG (2001 Facelift)
Jaguar XJR Supercharged (2002)
NIX
Good timing re thread, I could do with new bonnet insulation too..... along with the 101 other things I still need/want to do :roll: But at least this won't break the bank.
Jim320i
Mon Apr 04, 2011 3:10 pm
@Low_E30 - I think it comes only in a 3 part set to be honest, but you'd have to enquire... Also, the ones you say that are mint might turn out to be discoloured compaired to the new one
kieran325
Mon Apr 04, 2011 3:39 pm
It does come in a 3 part set.
