Mon Apr 04, 2011 9:58 am
Just found this old post on the net from another forum..gives an idea of the savings possible
Bulbs
Brilliant Headlight (Single) RRP £9.99 TRADE £3.50
Super Brilliant Headlight (Single) RRP £14.99 TRADE £7.50
Twinpack 12V 5W sidelight bulbs RRP: £2.49 TRADE: £0.46
Halfords Bulb Hbu382 21wat. Retail 2.49 Trade 48p
halfords extreme brilliance bulb 90% brighter retail £18.99 trade £15.99
Tools
Deep 15mm 1/2 Drive Socket - RRP 5.79 - trade £4.xx
Set of 12 1/2 Drive Sockets - RRP 17.99 - trade £14.xx
Laser Brake Spanners RRP: £3.99 TRADE: £3.19
Torque Wrench RRP: £49 TRADE:£39
120piece socket set RRP:£149 (but normally on offer at £99) TRADE:£89
150piece socket set RRP:£199 TRADE:£149
Laser Scissor type Ball Joint separator RRP:16.49 TRADE: 13.19
Halfords short 1/2" drive extension bar/swivel end combination type thing RRP: £5.49 TRADE: £4.39
magnetic flexible pick up tool- RRP £6.99, TRADE £5.59.
UPDATE: Halfords professional 18mm combination spanner RRP:6.49, TRADE: 5.19 (equivalent to 20% discount - probably same on all combination spanners). For sale in Durham for RRP £6.89 - TRADE £5.51
microdriver ratchet spanner professional little tool set thingy £10 trade £8
Halfords 2 tonne ratchet axle stands RRP £14.99 - Trade £11.99
Halfords Mechanics mat (Car creeper without wheels) RRP £14.99 - Trade £11.99
22 piece Halfords professional spanner set RRP £60. Trade £47
30 piece Halfords professional screwdriver kit RRP £30. Trade £22
oil filter wrench RRP £4.99. Trade £3.21
240V inspection lamp RRP £9.99 - Trade £7.99
Halfords Professional 24mm combination spanner RRP £9.49 - TRADE £7.59
Halfords Professional 1/2" drive 30mm deep socket RRP £7.29 - TRADE £5.83
Phaze 25 piece Flex Screw Driver Set - RRP £4.99 - Trade £4.99 - Saving £0.00
Halfords pro 16" breaker bar RRP: £15.99, Trade: £12.79
Deep 11mm 1/2 inch socket - RRP - £4.79 - Trade - £3.89
Bell Oil Drainer Can DC0601. RRP £4.79 - Trade £ 3.83
PRS Flex Spout Oil Funnel. RRP £3.99 - £ 3.19
Service parts
polo mk2 timing belt RRP £8.99 - TRADE £2.76 (CHEAPER THAN GSF!! )
Polo mk2 water pump RRP £32.99 -TRADE £21.11
halfords brand rear wheel bearing suit mk1 golf/polo RRP £11.99 Trade £8.37
Comma CV & Lith-Moly Grease 500G £5.49 Trade £4.39
BK 5000 universal cv boot kit, about £9-10 trade £3.64
Ignition components
Halfords Rotor arm HRA500 RRP £4.99 - Trade: £2.16
Glowplugs for 1.9 Diesel 206 RRP: £29.99 TRADE: £18.08
205 Distributor cap - RRP 8.99 Trade £6.19
Halfords set of 5 H.T leads RRP: £12.99 TRADE: £6.38
NGK 804 Sparkplugs - £9.99 RRP to trade £3.49
4 NGK spark plugs Grooved RRP £11.99 TRADE £4.32
Oil filters
Halfords Oil Filter for Ford Puma 1.7 RRP £5.29 - TRADE £1.90
Halfords OIL Filter for Citroen Xantia 2.0 8v RRP £6.49 - TRADE £2.01
Halfords Oil Filter for Toyota Yaris 1.0 RRP £5.99 - TRADE £2.44
Halfords Oil filter HOF204 - Trade £2.01
Halfords Oil Filter HOF265, various Ford, Jaguar RRP £5.29 - TRADE £1.90
Oil filter (either Halfords or Champion) for Toyota Starlet RRP £5.99. Trade £2.21
Halfords Oil Filter HAF293 - RRP £5.99 - Trade £3.70 - Saving £2.29
HOF237 (Nissan) RRP - £7.49, TRADE - £2.40
HOF301 (V/hall) RRP - £7.49, TRADE - £5.64
Halfords Oil Filter (HOF200, Saab) RRP - £3.99, TRADE - £1.74
oil filter for ford focus 1.6 04, part number HOF 265 RRP £5.79 TRADE £1.90.
Air Filters
HAF 249. Retail £9.99 Trade £2.44
HAF 410 RRP £14.99 - Trade £11.59
HAF 281 (Nissan) RRP - £10.79, TRADE - £4.82
HAF 366 (V/hall) RRP - £7.79, TRADE - £4.78
Fuel filters
HFF232 (Nissan) RRP - £11.99, TRADE - £6.66
HFF219 Fuel Filter - No idea on retail as it was from back room - Trade £5.39
fuel filter for 1.6 ford focus 04, part number HAF 283 RRP £11.79 TRADE £9.19
Halfords Fuel filter Xantia RRP £10.49 TRADE £6.30
Filters - others
Pollen Filter 006 RRP £9.99 - Trade £5.99.
Odds n Ends
Tube of Easy Gasket - RRP £4.99 TRADE £1.90
Loctite Instant Gasket - £3.99 Trade - £2.01
Halfords Split Pin selection approx 550 6 different sizes RRP: £6.99 TRADE: £4.99
Halfords Rocker switch RRP: £1.79 - Trade: £1.43
engine stop leak wynns £5.49 trade £4.49
halfords copper grease 500g £6.99 trade £3.88
pittards leather chamois rrp £15.99...no trade discount.
Reddex Petrol 1 litre RRP £9.99 - Trade £7.99
Superflex Windscreen silicon sealant RRP £4.49 - Trade £4.04
AirCon refrigerant top-up with pressure gauge RRP £39.99 - Trade £31.99
Loctite Stud 'n' Bearing sealant RRP £2.99 - TRADE £2.69#
Turtle Wax Ice Wax - RRP £12.99 - Trade £12.99 - Saving £0.00
Holts Tyre Weld - Large RRP £ 8.99 - Trade £8.99 - Saving £0.00
Halfords Tyre Tread / Pressure Kit - RRP £6.99 - Trade £6.99 - Saving £0.00
Wynns Engine Flush - RRP £4.99 - Trade £3.99 - Saving £1.00
WD40 250ml RRP £2.49, TRADE - £1.99
Halfords Fuel Hose HFH402 (1m length, 8mm diam) RRP £4.29, TRADE - £2.39
Halfords Trim Rivets (plastic) HFX363 - RRP £2.49 - Trade £1.99
Halfords Crimp & Terminal 'selection box' 180 pieces HBB105 - RRP £6.99 - Trade £4.99
Number plates: no discount for trade
Heatshrink tubing pack - RRP £6.99, Trade: £3.99
5 amp cable 7 metres various colours - RRP £2.99, Trade: £2.39
Copper Grease RRP £3.49 Trade £1.33
Halford's Fused Cigarette Lighter Plug RRP £2.99 TRADE £2.49
Sprays
Halfords Grease Spray RRP £3.99- Trade £3.19
3-IN-1 Professional silicon spray RRP £4.99 - TRADE £3.99
Loctite Freeze and Release spray RRP:£2.99 - TRADE £2.39
3 in 1 cleaner degreaser £ 4.49 trade £3.59
wynns carb/intake cleaner spray £4.99 trade £2.96
3-In-One Pro Copper Grease (aerosol) - RRP £4.49 - Trade £3.59
Cooling system
1ltr antifreeze RRP: £4.29 TRADE: £3.43
Holts Radweld RRP: £3.99 TRADE: £0.99
Halfords coolant hose repair bandage - RRP £2.99 - trade £2.44
halfords anti freeze 1ltr got 70p off.
Halfords Hose Clip ( the big Jubilee clip) RRP £1.59 TRADE £0.49
Thermostat + Fitting Kit for Citroen Xantia 2.0 petrol RRP £15.04 TRADE £11.28
Anti-Freez 5 liters can "2 yrs life" RRP £17.99 TRADE £14.69
Brake stuff
EUROPART ViziBleeding Kit ( with container) RRP £5.99 - TRADE £3.55
EUROPART ViziBleeding Kit ( without container) RRP £4.99 - TRADE £2.49
Halfords brake cleaner RRP: £5.49 TRADE: £4.39
Big Can of Brake and Clutch Cleaner - RRP £5.99 - (sounded expensive and it's a huge can)
Halfords Dot4 brake fluid - massive 5 litre can RRP: £15.99 - Trade: £10.21 (£2.04 per litre)
Ferrado Brake shoes for Fiesta, Ka, etc = £23.99 Trade £15.
Exhaust stuff
Halfords Exhaust Repair Bandage RRP£3.29 - TRADE £1.21!!
Holts Gun Gum Putty (for holes in backbox) - RRP £3.79 - Trade 76p!!
rubber exh hangers 34MM "O" style RRP:79 PENCE TRADE:55 PENCE
gun gum £3.79 trade 76p
fire gum £3.79 trade £2.17
Holts Flexiwrap for fixing the back box (the wide metal sheet) RRP £6.49 TRADE £4.20
Holts Flexiwrap for fixing the exhaust pipe into the back box RRP £5.49 TRADE £4.36
Holts Flexiwrap for fixing the exhaust pipe RRP £5.29 TRADE £3.30
Wipers
bosch wipers 23/21 retail £36.99 trade card £27.99
halfords wiper set 56. retail £23.99 trade card £12.13p
Windscreen Wiper Blade (Rear) - RRP £9.99 TRADE £3.47
bosch s/p wiper blade 19 retail £9.99 trade £4.45
21/19s bosch wiper set £18.99 trade £10.59
Set 20 wipers halfords (21inch spoiler and 19 inch blades same as bosch fitments) £14.49 trade £5.94
Bosch s/p Wiper Blade 15 RRP £7.49. Trade £4.22
Halfords Wiper Blade w22 17 RRP £6.79. Trade £2.70
Halfords rear wiper W13 RRP £6.39 - Trade £1.95
Batteries + Cables
hb065 battery £69.99 trade £45.14
hcb065 calcium 4 yr guarantee battery £79.99 trade £52.44
hb075 battery £74.99 trade £51.21
hcb075 calcium battery £84.99 trade £54.25
merc battery(one in boot) RRP: £99 TRADE: £71
Halfords Earth Cable 22cm RRP £3.99 - TRADE £3.19
Hyundai Coupe Battery RRP £96 Trade £71
Oil
15/40 5l part synthetic Oil - Trade £12.74
Castrol Magnatec 5W30, 4 Litres, RRP £27.99 - TRADE £22.39
Halfords Fully Synth 5w/40 Oil 5l. RRP - £34.99, TRADE - £26.24
Paints/Primers etc
upol weld thru primer RRP £10.99 TRADE £9.89
Aluminium spray paint RRP £5.79 - Trade £5.21
Touch up paint set, Vauxhaull Satin Red RRP £10.49. Trade £9.44
Primer spray paint RRP £5.79 - Trade £5.21.
Clear Laquer spray paint RRP £5.79 - Trade £5.21.
Halfords Alloy Wheel Repair Kit. RRP £29.99 - Trade £ 26.99
No discount on mixed paints.
Books and Manuals
Haynes manual 3797 ( Astra/Zafira diesel 1998-2004) RRP £18.99 Trade £15.19
Haynes Manual 3511 ( Mercedes C-Class ) RRP £19.99 TRADE £15.99
