Hi all please help i have bought a set of Borbet A's 9x16 et15 on the front the wheel is catching the caliper should i do? and what is the correct size tyre that should be on the wheel should it be 205/40/r16?
thank you
Borbet A advice
You will need some hubcentric spacers if its only brushing the caliper 2 or 3mm should do the trick, have a look on ebay. Your tyre size should be fine, there will probably be a bit of stretch with that width though.
Ive got a 3mm spacer (you can't get these hubcentric as they are so small) and mine clear the caliper by a couple of mm and i have a 60/40 drop on springs and shocks.
My tyres are 215/40/16 and sit perfect but may got 205/40 next time.
Hope this helps.
Will
Hope this helps.
Will
