finaly dropped 40mm
e30-ian
Mon Nov 22, 2010 6:02 pm
I took my e30 into work today and lowered it 40mm, but its never that simple, i had to buy 2 new wishbones costing £103!! then the antiroll bar swing support bracket snapped :( ive orderd a new one from bmw and will arrive tomorrow, drives a little bit better but dont really notice a big change in the driving
Mon Nov 22, 2010 6:11 pm
What springs did you fit? I lowered my first E30, a 1984 320i using I think Jamex ones, and it just cornered a little flatter with less roll, but it's all about the stance! 8)
Mon Nov 22, 2010 6:12 pm
were the ball joints goosed on the control arms ?
did you check your dampers ? -40mm is about right before you start eating sumps.
e30-ian
Mon Nov 22, 2010 6:18 pm
yeah they was goosed, well after i finished them off with the balljoint splitter they was :) ive used Gmax, it sits a little lower but i wanted lower than that but yes the worry was the sump, 40mm is right for a e30
Mon Nov 22, 2010 6:23 pm
Yes, you don't want to go any lower than that on E30s, else the rear tyres wear quickly and the handling is adversely affected.
e30-ian
Mon Nov 22, 2010 6:35 pm
how can i make it more stiffer to drive? im not 100% happy with it, i know i need to put a new antiroll bar swing support bracket on as its left loose but will be doing that in the morning, it just feels soft around corners, i cant describe it but it, just feels standard to me
Mon Nov 22, 2010 6:37 pm
Sounds like you probably need new dampers also. Bilsteins are good on these, if you can afford them.
320iAN
Mon Nov 22, 2010 6:39 pm
e30-ian wrote:how can i make it more stiffer to drive? im not 100% happy with it, i know i need to put a new antiroll bar swing support bracket on as its left loose but will be doing that in the morning, it just feels soft around corners, i cant describe it but it, just feels standard to me
lower springs only drop the height, to get the best from them you may need shorter, uprated shock's to get closer to the driving feeling your looking for
e30-ian
Mon Nov 22, 2010 6:42 pm
i was thinking shocks, will order some now then :)
Mon Nov 22, 2010 6:44 pm
you need dampers my preference is boge turbo on -40mm springz :D
e30-ian
Mon Nov 22, 2010 6:48 pm
found some supersport dampers from germany, £48 on ebay, anygood ?
320iAN
Mon Nov 22, 2010 6:53 pm
e30-ian wrote:found some supersport dampers from germany, £48 on ebay, anygood ?
got supersport shock's on my iS with Jamex -35mm spring's, the car feel's pretty good, but i also have both eibach anti roll bar's and my E30 is fully poly bushed
Mon Nov 22, 2010 6:57 pm
copy the link and paste it,i doubt they are any good.
ecp sell boge turbo.here are some arse end ones i bought ages ago and now have them all round thanks to h27 and lee parks on here .
CHR1S1990
Mon Nov 22, 2010 7:23 pm
my advice, sort yourself out with some new dampers (bilstein b4s will work fine with 40mm drop and not too expensive from ECP) and stiffen your drive the hartge way with some hefty ARBs, they make a massive difference
Andyboy
Alpina Colada
Mon Nov 22, 2010 9:57 pm
It also depends on what E30 you have. If it's a 4 cylinder or a 320i, it's worth adding a pair of 325i Sport anti roll bars. You'll get a pair for 50 quid.
Bilstein B4's work well with a 30mm drop, 40 should be okay but add a pair of new E36 Coupe front bump stops.
CHR1S1990
Tue Nov 23, 2010 10:57 am
Andyboy wrote:It also depends on what E30 you have. If it's a 4 cylinder or a 320i, it's worth adding a pair of 325i Sport anti roll bars. You'll get a pair for 50 quid.
+1. My 320i didnt even have a rear ARB on. How thick are sport ARBs?
e30-ian
Tue Nov 23, 2010 6:31 pm
Its a 325i 1988
e30-ian
Tue Nov 23, 2010 6:39 pm
ive orderd some Bilstein shocks, should be with me friday, after a few friends comments on how it now looks im sort of happy with it, gives it more of an aggressive look, i just need to get the vauxhall 17inch wheels off as they sit in far to much and go for a bmw fitment but that will be after christmas now unless a nice swap comes up :wink:
JoeDiese
Tue Nov 23, 2010 8:54 pm
I've been really pleased with my Bilsteins since I've had them on my personal e30. The change in handleing was enormous from the tired out non-BMW units the previous owner had installed at some point.
Less body roll cornering and hardly any perceptble dip of the nose when you dive on the brakes coming to a stop! Top kit!
